Between the rear windshield and the trunk lid - 1971 Oldsmobile 442
Old Oct 20, 2024 | 11:13 AM
keyboard's Avatar
Question Between the rear windshield and the trunk lid - 1971 Oldsmobile 442
Hello guys, I'll tell you.
I am working on the car, I have removed the front and rear windshield and I have ventured to remove the upholstery, sand and paint the floor.
Everything was fine until I removed the rear trim and saw what I show you in photos.
I also have the problem that when I wash it, water gets in, and I'm afraid that it could get into that area.
The sheet metal that I have just below has 3 holes where if I put my hand to feel it seems that there is something that is not right, an area that is too rough which makes me understand that there may be some rust.
What do you think? Is this an "invention" that was made to cars to protect the area or is it really a botched job to mask some area with possible rust?
I'm going to take it to the body shop soon and it would be very helpful to know your opinion on whether it's worth cutting and repairing.
Thanks in advance.
Regards
Old Oct 20, 2024 | 11:42 AM
Unfortunately rust there is all-too-common on these cars and no one makes a repro part.
Old Oct 20, 2024 | 02:53 PM
Hoffman2099's Avatar
WOW! That is rough. Here is a link to what that area should look like. These are the best photos I could find.
https://classicoldsmobile.com/forums...channel-72985/
Old Oct 23, 2024 | 01:49 PM
keyboard's Avatar
Hi guys.
Well, I think I should clean up that area, there is something I don't see quite right and I think the problem must be there.
Also, the link that Hoffman shared makes it a little clearer to me, in that area they put a kind of protector to cover the area, but even so it seems that it is not waterproof and water enters through there, I understand that it is because underneath It is not in good condition.
We will have to cut to confirm.
Thank you very much for the help guys.
Regards
Old Nov 22, 2024 | 02:57 PM
keyboard's Avatar
Hi guys.
I'm already fixing this area.
Looking at this photo, I would like to know if the area that I have marked in red is normally the same color as the body or is painted a different color.
The area that I have marked as blue I understand that it must be the same color as the body.
Thanks in advance.
Regards
Old Nov 22, 2024 | 03:26 PM
Loaded68W34's Avatar
The area in red should be the color of the interior, not the exterior paint color.
Old Nov 24, 2024 | 01:58 PM
keyboard's Avatar
Thanks for the help Loaded68W34
Old Nov 24, 2024 | 03:51 PM
keyboard's Avatar
Hello guys, one more thing.
I take advantage of this thread to ask about the dashboard and its front part (let's say it's the one between the dashboard and the engine).
Are they both in the same shade of black? What shade of black should each one be in?
Old Nov 24, 2024 | 04:12 PM
Underhood black is about 60% gloss. Olds used flat paint on the part of the dash under the windshield to prevent glare. The bottom of the dash is semi-gloss.
Old Nov 25, 2024 | 02:35 PM
keyboard's Avatar
Thanks for the help Joe.
Now I'm clear, I'm going to try to leave those areas as they came from the factory.
Old Dec 21, 2024 | 04:20 PM
keyboard's Avatar
Hi guys.
I have already picked up the car from the body repairman, he has fixed that area for me. Indeed, there was some rust and they waterproofed it with that black paste that is in the previous photos.
I hope that after this arrangement, that area will last another 50 years.
Thanks for the help.
Regards
Old Jan 9, 2025 | 12:37 PM
keyboard's Avatar
Hello guys, a question.
Will the area where I point out (mini red line) be blue or will it be covered once I install the windshield and chrome trim?
Thanks.
Regards
Old Jan 9, 2025 | 12:45 PM
Yes
Old Jan 12, 2025 | 04:59 AM
keyboard's Avatar
Yes
Hi sir.
Only to confirm it, will it be covered?
Thanks.
Regards
Old Jan 12, 2025 | 05:37 AM
dc2x4drvr's Avatar
Suggestion, dry fit the glass to check for alignment, especially at the bottom.
Old Jan 12, 2025 | 05:53 AM
Originally Posted by keyboard
Hi sir.
Thanks.
Regards
Was "yes" not clear? The trim sits on the glass and runs all the way to the trunk lid. No part of that metal shows.
Old Jan 12, 2025 | 12:30 PM
keyboard's Avatar
¿No quedó claro el "sí"? La moldura se apoya sobre el vidrio y llega hasta la tapa del baúl. No se ve ninguna parte de ese metal.
Sorry Joe, my English has made me doubt the question I asked.
Thank you sir.
Old Jan 12, 2025 | 12:31 PM
keyboard's Avatar
Sugerencia: ajuste en seco el vidrio para verificar la alineación, especialmente en la parte inferior.
Thanks for the advice
6D7 442
Nov 5, 2024 02:26 PM
Schne442
Jul 24, 2024 05:55 PM
Taz54904
Mar 26, 2024 09:24 AM
72455
Body work
15
Feb 22, 2024 06:26 PM
Brian Young
Apr 30, 2020 09:37 PM
