Fresh chrome front bumper: now scrap
Old August 19th, 2018, 06:39 PM
NotDads442's Avatar
My bumpers were off my car when I bought it. It came with two sets. Evidently some ******** cut off the original tabs on the bottom and welded these on. Of course they don’t line up. $800 down the *******.
NotDads442 is offline
Old August 19th, 2018, 07:41 PM
Run to Rund's Avatar
make a bracket, bolts to both holes.
Run to Rund is offline
Old August 19th, 2018, 07:58 PM
Olds Fever
CRUZN 66's Avatar
Something just doesn't look right... It almost seems that the tab is bent in the wrong direction... Do you have a better view of the overall bumper in relation to the tab??? It's hard to believe the tab was cut off and re-welded... Since the bumpers were not on the vehicle when you purchased it, are you sure the brackets are correct and in the correct location...
CRUZN 66 is offline
Old August 20th, 2018, 07:36 AM
I would be inclined to come up with a solution also. Possibly modify the black part and repaint.
oldcutlass is online now
Old August 20th, 2018, 07:42 AM
66-3X2 442's Avatar
I agree,something doesn't look right. If he would post a picture showing it from a distance,maybe we can figure it out. That tab has not been cut and welded. What year is the bumper?
66-3X2 442 is online now
Old August 20th, 2018, 08:12 AM
My442's Avatar
Test fit bumpers BEFORE you re-chrome them.
Ask me how I know.
My442 is offline
Old August 20th, 2018, 09:17 AM
NotDads442's Avatar
The car came with 2 sets of bumpers. I kept the other ones and looked last night. I don't know if it was my chrome shop or someone back the in the day modified the tab, but the non reworked ones look more like the ones in the FSM with a tab that is part of the bumper going vertical towards the hood if on the car. For some reason that upward tab is gone on mine. I don't know why anyone would have done this back in the day and then gone through the task of putting it in the wrong spot.
NotDads442's Avatar
Originally Posted by 66-3x2 442
i agree,something doesn't look right. If he would post a picture showing it from a distance,maybe we can figure it out. That tab has not been cut and welded. What year is the bumper?
1967
Old August 20th, 2018, 10:26 AM
RandyS's Avatar
Hi, please post a pic of the complete bumper from the back side, also the mounting brackets. 66 & 67 mount the same way, and I don't have any vertical tabs on my 66.
RandyS is offline
Old August 20th, 2018, 02:26 PM
66-3X2 442's Avatar
There are two sets of tabs on the bumper. One is for the bracket and the other is for the rubber air flap to fit over. Which one is missing?
Old August 20th, 2018, 05:50 PM
NotDads442's Avatar
Passenger side tab
View from drivers side to passenger side
Old August 20th, 2018, 06:03 PM
66-3X2 442's Avatar
Are you positive you have 67 brackets and not 66's?
Old August 20th, 2018, 06:06 PM
NotDads442's Avatar
No, I’m not sure. The bumpers and brackets were off the car. My dad has a 67 and said his bumpers have that piece that comes up. The 67 assembly manual shows that too.
Old August 20th, 2018, 06:22 PM
NotDads442's Avatar
So 66 brackets might get me out of this jam?
Old August 20th, 2018, 06:38 PM
66-3X2 442's Avatar
The 66 & 67 brackets look a lot alike but will not interchange. Before you do anything,I would find a known correct 67 bracket to check.
Old August 22nd, 2018, 04:21 AM
goldie442's Avatar
good morning...i have several sets of 66 brackets if you should need them...good luck!...kim ...classics@htc.net
goldie442 is offline
Old August 22nd, 2018, 08:45 AM
NotDads442's Avatar
do you think I have a 66 front bumper? The other bumper I have upstairs seems to have those tabs closer to the outside of the bumper
Old August 22nd, 2018, 08:48 AM
66-3X2 442's Avatar
Post a picture of the front of the bumper or does it have a single oval opening in the middle of the bumper or two openings on both sides of the tag area?
Old August 23rd, 2018, 07:50 AM
lemoldsnut's Avatar
I can do either 66 or 67 brackets. 67 lower bumper tabs do not look like that.
Do you have incorrect bumpers? If you post a picture or pictures of the bumper so we can see the entire thing from both sides that would help to help you.
I will post a picture of my 67 lower bracket to bumper
Larry
lemoldsnut@aol.com
lemoldsnut is offline
Old August 23rd, 2018, 12:20 PM
RandyS's Avatar
If you really want some help with this issue, why not post the pics that several have asked for???
RandyS is offline
Old August 23rd, 2018, 06:42 PM
NotDads442's Avatar
Larry my dad confirmed his 67 bumper has that rise in it like the one in the picture. I also googled a 66 442 and I definitely don’t have a 66 front bumper. My openings are clearly 67. This leads to two conclusions.
1) my chrome shop did something
2) someone in the past did for whatever reason and modified the bracket
Old August 23rd, 2018, 09:32 PM
NotDads442's Avatar
The rises in the bumper dip back down again and don’t continue along the lines of the filler between core support and bumper
No sharp line. Bolt hole in wrong spot
Tabs not centered for support
Well the bumper is scrap. I honestly believe now after really looking at my bumper and then the other core bumper at my shop; that the chrome shop gave me the wrong bumper back.
1) the groove where the rubbers fit against the fender is way too tight, the “V” is way too acute
2) this center support where the bumper attaches to the hood release support has no mounting holes (see pictures)
3) and most obvious is the sharp lines of the 67 bumper are not on this freshly chromed bumper. (See pics).
Million dollar question is whose bumper did I get and what car does it fit.
Old August 23rd, 2018, 09:46 PM
lemoldsnut's Avatar
if you back up and take a picture of the entire bumper it will help others help you
Old August 23rd, 2018, 09:51 PM
NotDads442's Avatar
Old August 23rd, 2018, 09:56 PM
lemoldsnut's Avatar
that is not a 67 Cutlass/442/f85 bumper very different than what you have
Old August 24th, 2018, 06:26 AM
l6conv's Avatar
bumper
looks like a 68 to me
l6conv is offline
Old August 24th, 2018, 06:44 AM
Old School Olds
tru-blue 442's Avatar
It does look like a 68.
https://www.ebay.com/i/400607109425?chn=ps
tru-blue 442 is offline
Old August 24th, 2018, 08:10 AM
lemoldsnut's Avatar
I agree here is my 68 looks just like it.
Old August 24th, 2018, 08:12 AM
That definitely is not a 67, the shape is wrong and it has a built in license plate bracket.
Old August 24th, 2018, 06:46 PM
NotDads442's Avatar
Called the chrome shop today and went over there with my other 67 bumper and that one. Obviously not the same, the owner was out until Tuesday but the guy there said they'd likely chrome my other one free of charge. Oddly no one has brought back mine.
Old August 24th, 2018, 07:03 PM
  #31
66-3X2 442's Avatar
Just curious. You had another 67 bumper and you couldn't compare them to see the difference?
Old August 24th, 2018, 07:41 PM
  #32
NotDads442's Avatar
I brought the fresh bumpers to my house and stuck them in the basement. Left the newspaper on them for quite awhile. The other bumpers I left at my auto repair shop upstairs in storage. I dropped off two 67 sets at the chrome shop that day last year and took the crummier ones back to my shop.
Old August 24th, 2018, 07:52 PM
  #33
lemoldsnut's Avatar
I'm not sure anyone else has the "*****" to say it but read your original post. (some ********) apparently did not do anything, And it is as simple as you did not check it against the other bumper you had. Yes the shop made the mistake of giving you the wrong bumper. But, Gee lets just start calling everyone a name and blaming and on and on.
I hate when people do this. Thought you should be told. It was hard to help you as you were reluctant to give us the picture all asked for to see the bumper not small parts of it.
I know you will get all pist at me now and make comments about me. But, the point is; research with a positive result out come in mind, is better than going off on someone.
Just my 2 cents
Larry
Old August 26th, 2018, 08:05 AM
  #34
NotDads442's Avatar
Just my 2 cents
Larry
Nah. We’re good Larry. You’ve been good to me. Helping me out on parts and what not.
lemoldsnut
November 4th, 2022 07:11 AM
ByronF
January 28th, 2018 07:49 PM
Allan R
September 20th, 2011 12:30 PM
defiant1
October 9th, 2010 07:21 AM
tim72
June 7th, 2009 01:25 PM
Quick Reply: Fresh chrome front bumper: now scrap
