W-25 Hood a bit flaky
Old February 2nd, 2018, 01:03 PM
MyBlue72's Avatar
I have an original W-25 hood that I plan on putting on my 72 Cutlass. It has already been painted, but unfortunately the idiot that did the job had a small shop and left my hood outside, upside-down in the elements. So now when I move the hood around I can hear loose scale rust sandwiched inside between the metal frame and the fiberglass.
I dread having this hood put on knowing that is in there.
Have any of you had this issue with one of these W-25 hoods.
Any input on a way to get this loose rust out of there without doing damage to the hood?
Thanks,
Doug
MyBlue72 is offline
Old February 2nd, 2018, 04:51 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
How long in the elements? You're in NC. So unless its been left out for 30 years its likely not rust just debris. Leave it alone. Unless you want to destroy an OEM hood trying to peel the frame out.
droldsmorland is offline
Old February 2nd, 2018, 04:57 PM
stevengerard's Avatar
I second that. heck every time I open my hood it makes more creaking sounds then my knees. With out pictures or an audio file its hard to tell
stevengerard is offline
Old February 2nd, 2018, 06:59 PM
MyBlue72's Avatar
It was outside collecting rain like a giant bird bath for a couple of weeks. I'm hoping you're right as far as debris. I didn't see any way to get it out of there other than drilling or separating a seam, which I didn't want to do.
I guess I will have to live with it.
Thanks,
Doug
MyBlue72 is offline
Old February 2nd, 2018, 07:01 PM
MyBlue72's Avatar
Lol. I feel your pain Steven.
MyBlue72 is offline
Old February 4th, 2018, 03:44 PM
Stefano's Avatar
The fiberglass and metal frame can be disjointed and then reunited but best left to someone who has done this a few times!
Spend some time with a flexible air nozzle and a good air compressor, to blow it out.
Stefano is offline
Leadfoot
February 5th, 2014 03:58 PM
dhartley72
June 13th, 2012 06:52 PM
jpaulwhite
Ninety-Eight
August 3rd, 2010 08:35 PM
Chopper
December 9th, 2008 02:50 PM
ct1979
March 10th, 2008 01:10 PM
Quick Reply: W-25 Hood a bit flaky
