Trim removal on '72 98
Old Sep 23, 2023 | 03:49 PM
jpilk99's Avatar
Hi all. Can someone give me guidance on removing the horizontal chrom trim on the door; and how to repair the final mounting point that holds/supports the trim at the edge of the door? Also, how to remove the ...lower rocker cover just in front of rear wheel (see pics)?
Old Sep 24, 2023 | 03:45 AM
In your second picture you can see the anchor for the door trim in the middle of the door. The anchors slide onto a stud that's welded to the door skin. The stainless trim snaps onto the anchors. You can get new anchors that aren't so worn out. Make sure you bend that trim back into place before reinstalling it.
Old Sep 25, 2023 | 02:58 PM
jpilk99's Avatar
Any chance you have a name or part number or image of what these "anchors" look like so I can go buy some? Thank you.
Old Sep 25, 2023 | 04:32 PM
Unfortunately, reproduction clips/anchors sometimes don't work. Make sure you remove the trim per the Chassis/Factory Service Manuals and match the clips/anchors up to the ones you need. CSM/FSM are pretty necessary for this task because you might damage the trim if you remove it the wrong way (ask me how I know).
Here's a good supplier.
https://www.restorationspecialties.c...ers_c_246.html
Old Sep 26, 2023 | 07:37 PM
jpilk99's Avatar
Thank you!!!!
evil442
Mar 27, 2023 09:15 AM
omy442
Mar 9, 2023 07:20 PM
holidaysedan
Oct 30, 2022 09:11 AM
MMoney
Body work
May 30, 2020 01:22 PM
Brians1
Feb 16, 2020 03:47 PM
