Rocker Panel Mounting hardware - 72 cutlass
Old Nov 13, 2022 | 04:57 PM
LNCTIME's Avatar
Searching for rocker panel mounting hardware. When googling, it is hard to discern what I need exactly. Each search result appears to show different mounting hardware. So besides the screws on the bottom, there should be clips. Is that the metal round hardware with screws in the middle? Many sites say they are incompatible with the 72 cutlass. Any insight would be much appreciated.
Thanks all. A week in on my new 72 cutlass. This weekend, swapped out the front shocks, installed hood lamp, installed new parking lights, and rejuvinated the trunk. Installed new OEM driver side mirror with remote and trim. Best of all, drove and enjoyed it.
Thanks again all for the support.
-Paul
Old Nov 13, 2022 | 05:34 PM
vette442's Avatar
Yes, you need the stamped steel circles with screws in the middle. I think I have a bunch of OEM ones from an Arizona ‘72 Supreme.
Terry
Old Nov 15, 2022 | 10:11 AM
pizza442's Avatar
OPGi has the repro discs (pricey) if you can't find enough. I was lucky enough to save mine and the little screws, but can't find the other screws that bolt the chrome piece to the underside of the rocker panel. Any idea exactly what screws those are? The little ones from the metal discs are not the same size...
724drcutlass
Jan 11, 2021 12:31 PM
Scottsand1983
Oct 9, 2018 06:08 PM
72KeysCutlass
17
Feb 2, 2017 10:06 AM
Gary's 2 442-S
Nov 9, 2011 05:46 PM
MJAKS462
May 30, 2011 05:38 PM
