Rocker Panel Mounting hardware - 72 cutlass
Searching for rocker panel mounting hardware. When googling, it is hard to discern what I need exactly. Each search result appears to show different mounting hardware. So besides the screws on the bottom, there should be clips. Is that the metal round hardware with screws in the middle? Many sites say they are incompatible with the 72 cutlass. Any insight would be much appreciated.
Thanks all. A week in on my new 72 cutlass. This weekend, swapped out the front shocks, installed hood lamp, installed new parking lights, and rejuvinated the trunk. Installed new OEM driver side mirror with remote and trim. Best of all, drove and enjoyed it.
Thanks again all for the support.
-Paul
-Paul
OPGi has the repro discs (pricey) if you can't find enough. I was lucky enough to save mine and the little screws, but can't find the other screws that bolt the chrome piece to the underside of the rocker panel. Any idea exactly what screws those are? The little ones from the metal discs are not the same size...
