Need help on 1983 delta 88 rear quarter panel/ fender was in a wreak and bent up pretty good is it possible to replace it off a parts car if so how or do I have to try pulling dents out any help thanks
You can get a quarter panel skin from a parts car but you have to have some fabrication, welding and metalworking skills to do it. If it's just caved in I'd pull the dents and metal finish it.
Is it beat up bad around the fender crown or taillight area? Pic will help us tell you which route to take.
Photos would definitely help a lot.... If the damage is not near any major defined body lines, pulling may be a good option, otherwise you may be looking at replacing the quarter or section of the quarter.....
It's a fixer. Will take someone with true body work skills but yes that can be fixed.
Thanks the good news I wanted to hear think it could be fixed with a slide hammer dent puller? Want to try fix all body work myself ant got be perfect but decent
i fixed this just last week at work. metal was actually pretty thick for a newer car. Normally we would replace the panel BUT there was not readily available replacement and none in the salvage yards local. Due to time constraints in a production body shop they opted to repair it. Metal straightening is my specialty in our shop so it became my baby lol. With 50 hrs of booktime which also included the doors and trim im only in it 17 so far. not too shabby.
