Rear quarter panel
Old December 29th, 2015, 10:15 PM
1983oldsmobiledelta's Avatar
Rear quarter panel
Need help on 1983 delta 88 rear quarter panel/ fender was in a wreak and bent up pretty good is it possible to replace it off a parts car if so how or do I have to try pulling dents out any help thanks
1983oldsmobiledelta is offline
Old December 30th, 2015, 11:45 AM
Oldsdruid
rocketraider's Avatar
You can get a quarter panel skin from a parts car but you have to have some fabrication, welding and metalworking skills to do it. If it's just caved in I'd pull the dents and metal finish it.
Is it beat up bad around the fender crown or taillight area? Pic will help us tell you which route to take.
rocketraider is offline
Old December 30th, 2015, 11:56 AM
Olds Fever
CRUZN 66's Avatar
Photos would definitely help a lot.... If the damage is not near any major defined body lines, pulling may be a good option, otherwise you may be looking at replacing the quarter or section of the quarter.....
CRUZN 66 is offline
Old December 30th, 2015, 12:23 PM
lemoldsnut's Avatar
Often even if replacing a quarter panel you need to pull the damaged one somewhat straight to make is so the replacement panel will mount up.
lemoldsnut is offline
Old December 30th, 2015, 01:51 PM
I post a pic later to day but its really bad by the door
Old December 31st, 2015, 09:08 AM
Oldsdruid
Did it get the lock pillar and/or dogleg in front of the wheel opening? and if it did, can you open and shut the door?
Old December 31st, 2015, 06:44 PM
Here's a pic and door opens and shuts fine
Old December 31st, 2015, 06:46 PM
lemoldsnut's Avatar
It's a fixer. Will take someone with true body work skills but yes that can be fixed.
Old December 31st, 2015, 08:20 PM
Thanks the good news I wanted to hear think it could be fixed with a slide hammer dent puller? Want to try fix all body work myself ant got be perfect but decent
Old January 1st, 2016, 11:56 AM
Olds Fever
CRUZN 66's Avatar
X2.... a real good body man should be able to pull that....
CRUZN 66 is offline
Old January 1st, 2016, 12:04 PM
Chevy budget Olds powered
coppercutlass's Avatar
That can be fixed as long as the metal is strong enough to be pulled. if anything the dog leg can be sectioned in and the upper portions repaired.
coppercutlass is offline
Old January 1st, 2016, 12:07 PM
i fixed this just last week at work. metal was actually pretty thick for a newer car. Normally we would replace the panel BUT there was not readily available replacement and none in the salvage yards local. Due to time constraints in a production body shop they opted to repair it. Metal straightening is my specialty in our shop so it became my baby lol. With 50 hrs of booktime which also included the doors and trim im only in it 17 so far. not too shabby.
Old January 1st, 2016, 08:01 PM
FN723's Avatar
No worse than that dent is, you could pull it out with a lot less work than replacing it even if you had a replacement quarter panel.
FN723 is offline
Old January 2nd, 2016, 09:04 AM
Thanks for the help y'all
m1369d
Body work
February 15th, 2014 12:41 PM
beebee78
September 2nd, 2013 09:54 PM
Jay D
Body work
November 17th, 2012 03:26 PM
2blu442
August 10th, 2012 03:38 PM
Wilson05
Body work
March 7th, 2009 03:22 PM
Quick Reply: Rear quarter panel
