Question about window gasket installation
Old Sep 26, 2021 | 02:44 PM
Electronic Memory's Avatar
So I have a 1947 Oldsmobile 76 fastback coupe with a rear window leak. I bought a new rubber rear window channel (essentially a piece of rubber weather strip with the ends fused together and some grooves/channels in it) from Fusick along with a bunch of weather stripping to fix various leaks.
I'm basically down to the Rear window channel rubber and I have a question before I start on this. Do I want to use some type of sealant between the rubber window channel and body and or between the window channel and glass, and if so do I want to use the same "3M Black Super Weatherstrip and Gasket Adhesive" 3M part number 08008 that I used on the trunk and door weather strips or something else (if so what product?).
The rear window on the fastback is almost a sunroof (especially with the previous owners front end lowering that I plan to undo) and water will pool at the bottom corners of the window.
Old Sep 26, 2021 | 02:59 PM
A friend of mine who is in the glass business swears by this stuff. 3M auto bedding and glazing compound.
3M™ Auto Bedding and Glazing Compound | 3M United States
Old Sep 26, 2021 | 03:45 PM
Yellowstatue's Avatar
^^^ Thanks for that. I want to do the rear windows on my '57.
Old Dec 24, 2021 | 05:04 PM
Thanks,
That was just what I needed to make my new rear window gasket seal properly.
I made a video about getting my car out of storage last Easter.
stevestringer
Apr 19, 2020 05:00 PM
armycav0
Nov 1, 2014 09:10 PM
navvet
Mar 11, 2012 06:08 AM
Warhead
Sep 26, 2010 07:24 PM
fizzy55
Sep 30, 2009 09:18 PM
