“Ninety Eight” script removal by rear bumper on ‘72
Old Oct 17, 2023 | 05:24 PM
jpilk99's Avatar
I’m doing a little work on rust spots on rear quarters and need to remove the “Ninety Eight” scripts. It looks like their legs are almost like rivets inside the trunk; see pics
. How should I remove so I can reinstall when done? Thanks
Old Oct 17, 2023 | 06:46 PM
Oldsguy's Avatar
Past Administrator
From my experience with similar trunk scripts they are in fact a kind of rivet. I have removed some before that were loose already and forced some out by striking the ends of them from the inside of the panel but then you run the chance of enlarging the corrseponding hole. Not sure if there is a non-destructive way to do it. Good luck.
Old Oct 17, 2023 | 06:47 PM
rocketraider's Avatar
Oldsdruid
They were originally installed with what's called a Tinnerman nut that screwed onto the mounting studs. Those look like they may have been removed before and the studs broke, and they were either glued back on or may have been installed using barrel clips.
You can try two things. First, use a small plastic hammer to see if you can tap them out from inside the trunk, or get a stiff bladed putty knife or plastic trim removal tool and see if you can pry them off from outside the car. You can get either at Harbor Freight.
*edit* Looks like someone's been in there before and there's some body filler in the panel. It may be thick enough to have caused issues remounting the script.
Old Oct 18, 2023 | 02:47 AM
^^^THIS^^^
Just be careful. Try to gently tap them out with a hammer from the backside.🤞
Old Oct 18, 2023 | 06:49 AM
jpilk99's Avatar
Thanks All. This car, which I love, is definitely only a "driver". It has PLENTY of blemishes. I'll do my best not to add to those blemishes. Just want to slow the progression of rust. Thanks again!!!
Old Oct 19, 2023 | 12:46 PM
jpilk99's Avatar
Update: I was able to remove the scripts. I wire brushed the stems and then took a wood-handled tool and "butt"ed them out. All good. Thanks all.
Old Oct 19, 2023 | 01:04 PM
Glad they didn't get damaged during removal.👍
Old Oct 20, 2023 | 05:39 AM
Oldsguy's Avatar
Past Administrator
Good to hear it.
Platinum Al
Dec 21, 2017 05:55 PM
KDW
Aug 26, 2016 07:46 PM
Alex72cutty
Jul 26, 2012 01:56 AM
Thomas Simcich
Body work
Oct 20, 2011 10:24 AM
cmarshall
Nov 13, 2009 04:50 PM
