need help with my front bumper
Old Feb 8, 2013 | 07:37 AM
shakeyhands73442's Avatar
I have a 73 cutlass. is there any way to move my front bumper back towards the body kinda like a 72
Old Feb 8, 2013 | 02:07 PM
I know they got the 5 mph bumper on it but didn't know if i could back it up or not
Old Feb 9, 2013 | 05:01 PM
ThePackRat's Avatar
Big Daddy No Bucks
Was it pressurized cylinders they were using then to achieve the 5 mph rating ?.
Could drill & de -pressurize them I suppose
(standard injury disclaimer - do you research & be CAREFUL)
Or ... Remove them all together & rig up something else in their place as mounting points.
Better yet - what I would do if I ever owned a 73 ...
Put a 74/5 nose on it.
Not a perfect solution ... but better front bumper than a 73.
Old Feb 9, 2013 | 05:25 PM
Doc350s's Avatar
Saw a 73 Supreme at a show once where the guy had pushed the bumper into the grills. Near as I can figure he either removed the 5 MPH shocks and built a bracket to remount or drilled new holes in the existing mounting hardware and moved the whole assembly back. May want to size it up before hand as I'm not sure if you would get the clearance you want. 74-75 bumper would require a different nose and plastic parts on the sides as they are different.
Old Feb 10, 2013 | 04:46 AM
aretubj's Avatar
I remember reading something about doing this.
If I remember correctly, there was a proceedure because of the pressurized cylinder.
There were two holes drilled initially in the cylinder, then one more to secure the piston in the collapsed position.
Personally I think it looks awful, too much front end.
Old Feb 10, 2013 | 06:32 AM
Really wanting to do this just don't know how or where to start
deltas1982
Dec 7, 2014 06:19 PM
75hurstoldsW-30
Aug 21, 2014 01:20 PM
98 man
Jun 10, 2014 04:39 PM
Alex72cutty
Jul 30, 2012 06:31 PM
jpaulwhite
Jul 22, 2010 07:01 AM
