Convertible Top Motor
Old March 2nd, 2018, 06:02 AM
timothypaul's Avatar
Good Morning,
Can any one tell me the best was to fill a convertible top motor with fluid on a 71 Supreme.
Most of the stuff I saw were for more modern convertibles. Also, I was going to use Dex III tranny fluid. Is that correct ?
Thank you....
Tim
timothypaul is offline
Old March 6th, 2018, 05:48 PM
atric's Avatar
Fisher Body Service Manual says fill with Type A or Dextron. The hyd pump motors in my exp have either a rubber plug or a small screw cap on the reservoir section of the pump for refilling. The pump is back behind the center of the rear seat. In my exp these don't leak. If it's low then one of the actuator cylinders are leaking. You can refill but depending on how bad the leaking is it can take days to months/years to run back low.
atric is offline
Old March 7th, 2018, 12:16 PM
TripDeuces's Avatar
http://topsdown.com/pages.php?pageid...hockwave+Flash
http://www.hydroe.com/Tips_-_Cylinders__amp__Pumps.html
The internet is your friend. There's a lot more where this came from.
TripDeuces is offline
ros6872
June 11th, 2016 05:20 AM
ros6872
May 21st, 2016 09:00 PM
GoBigRed
Brakes/Hydraulic Systems
15
October 5th, 2015 01:00 PM
bittersweet71
December 9th, 2009 09:21 AM
Quick Reply: Convertible Top Motor
