convert motor/cylinders
Old Oct 9, 2012 | 05:55 AM
ej69's Avatar
finally getting tired of manually raising top of 69 convert and want to get system working again. guy i bought it from said he disconnected system due to leak, but upon inspection last week, its disconnected and pump is completely removed.
a few questions, anybody know anybody that sells rebuilt pumps including resoivoir (sp?) 3 hole design? Also, are hydraulic top cylinders rebuildable. I'm not sure of their condition, but thought might be good idea to get them serviced if possible. last question, what are procedures for filling/bleeding system
thanks for help, eric
Old Oct 9, 2012 | 06:31 AM
dancutlass's Avatar
Hey Eric,
I don't know if the 69 top cylinders are the same design as the 66 cylinders, but mine could not be rebuilt, because it's pressed together!
There are special tools to fill/bleed the system, or you just follow the instruction written in the description of that item here: http://www.ebay.com/itm/140767568648...WAX:IT&vxp=mtr
As for the pump, check fusicks,ebay, opgi, the should have one for you!
Old Oct 9, 2012 | 01:46 PM
ej69's Avatar
thanks for link. anyone know how to test convert top cylinders other than putting motor in and firing up system. is it usually agood idea to replace hydraulic hoses also, or do they hold up well over time?
Old Oct 9, 2012 | 02:14 PM
69442C's Avatar
I have a used original pump from a 69 442 and it has the 3 mounting points. The motor runs great although I have not tested the pump action. Very clean so I would think it would work just fine. Let me know if you are interested. $75 plus the shipping.
Oh, cylinders can't be serviced and hoses should be changed too.
Brian
Old Oct 18, 2012 | 06:06 PM
ej69's Avatar
used the convertible siteon ebay and bought pump and hoses and was ableto get everything up and operating again
thanks for tip on ebay site
vistacruiser1971
Nov 9, 2013 01:19 PM
allyolds68
Aug 21, 2013 07:45 PM
Nasty455
Apr 9, 2012 11:06 AM
cts-v
Jan 22, 2009 12:44 AM
blue72regency
Nov 10, 2007 05:02 PM
