pinchweld molding
Old Oct 20, 2012 | 03:07 PM
ctsplicer's Avatar
pinchweld molding
OK maybe a dumb question, but I need to ask just the same.I have a 64 Cutlass convertible.I need to remove the pinchweld molding.I have looked in the manual,nothing.They have no screws so it will have clips.I need to remove the molding without destroying it as I am restoring the car for my wife.Any help would be greatly appreciated.
Old Oct 20, 2012 | 05:00 PM
Pacecar's Avatar
Try looking in a Fisher Body Service Manual for that year. I do not know anything about early 1960's. The pinch welds I have seen are generally just pressed on. I have come across situations where there is one screw behind the quarter window fuzzz to hold the top in place. Sorry could not be much more help
Old Oct 20, 2012 | 05:31 PM
ctsplicer's Avatar
Thank you.I'll see if I can find a fisher body manual.
Old Oct 20, 2012 | 05:44 PM
rcorrigan5's Avatar
Randy C.
To add what Pacecar said, the clips on my '68 convertible are each held in by one screw that you can only see/feel when the top is half way up/down. If yours in the same, the screw head can be felt/seen on the inside edge that's exposed when the top is in that position. There also might be some sort of sealant that you will need to pry loose if it's there. Just take your time and be careful.
When re-installing the pinchweld, I put the clips in place, each with the single screw to hold it there, and then the pinchweld snapped into place.
Don't know if yours if the same or not but, if it is, this might help.
Randy C.
ctrain22
Body work
Oct 9, 2010 01:46 PM
ctrain22
Paint
Feb 15, 2010 02:23 PM
luddie
Jun 28, 2009 05:33 PM
4Forty2
Aug 21, 2008 10:57 AM
luddie
Aug 5, 2008 08:30 PM
