Do I need new rings with new pistons? Ball honed cylinders.
I've gotten a lot of good help and advice about the '72 455 I'm planning to put in my Cutlass Supreme. Short story... due to budget constraints, I'm not going to do any machining at this point, but I am going to swap in a set of used standard bore high compression pistons graciously donated by another forum member here (thanks Dan B). The engine will be torn apart in about 2 years for a 'real' rebuild (bore, cyl heads, roller rockers...).
If I ball hone the cylinder walls, I presume I'll need new rings? All 3 rings need replaced? If so, is there any particular type of ring you would suggest, or will off the shelf "Autozone" or "NAPA" rings work?
This will be street only car, so I'm not looking for max power (though I guess I am looking for more power if I'm wanting the higher compression pistons).
Thanks. Tom.
Thanks. Tom.
Last edited by cts-v; January 15th, 2009 at 05:40 PM. Reason: clarifying that the pistons are 'used'
You should at least put new rings and brg's. Check with "Summit' and rings are $20 to no end. Get a set of cast rings and you will be good to go. When you check "Summit" look up the rings by size not by engine.
Also be sure to have the crank polished. Be sure to hot WASH the block, not hot tank.
Gene
Gene
New Rings?
Ring gap will probably be wide anyway, based on the fact that the bores are probably worn a bit. Unless you go to file fit (more money), that's a futile effort.
Make sire you wash the bores really well, good enough is not good enough. You'll eat up a set of rings (especially cast) and bearings pretty quickly if you don't.
88hurstolds
April 27th, 2011 12:13 PM
1k442
November 30th, 2009 12:37 PM
