Color matching interior and hacked plastics
Old Feb 4, 2024 | 11:50 AM
rfpowerdude's Avatar
This is for the 1970 Cutlass S interior.
I need to get some interior paint to fix the dash pieces I acquired to replace the hackery. Also, The Parts Place only has the front kick panels in black so I would need to paint them gold too.
The question: what is the color name of my interior that is gold colored? Is it "gold" or "mustard gold" or?
I also need to replace the underdash piece that was chopped up to mount stuff by the previous owner.
Anyone have one of these?
Old Feb 4, 2024 | 12:43 PM
Does the trim tag have the interior color code on it?
Old Feb 4, 2024 | 02:05 PM
Here's the cowl tag:
Old Feb 4, 2024 | 02:23 PM
Old Feb 4, 2024 | 03:22 PM
Your best bet for OE color paint is SEM. Otherwise, just get rattle can paint at the hardware store.
https://semproducts.com/products/market/upholstery-trim
Old Feb 4, 2024 | 03:41 PM
Def will get SEM.
What am I looking at Joe? I am guessing I need to decode the cowl tag first? Then look at the paint chart?
Old Feb 4, 2024 | 04:59 PM
Originally Posted by rfpowerdude
Def will get SEM.
That is from the Product Information Manual. It provides both the locations for each color in the interior and the paint codes.
Old Feb 4, 2024 | 07:39 PM
70Post's Avatar
Highly doubtful that SEM makes that color.....at least in terms of being one of their "standard" colors that are in their Color Coat line of paints for vinyl and plastics.
You may find someone to mix something locally but who knows???
I probably have that lower vent piece and also have a '70 gold interior paint I had mixed per the PPG interior color paint code.
If the pic you show is what you have now then you might want to remove the two "louvered" vents to transfer them over to whatever lower AC vent valance panel you get.
I'd have to have a complete address to get a good shipping quote.....would probably want to use a good reinforced box for shipping since that piece is long and not a real strong item. I could paint the piece with the goldl mix I have but no guarantee it'll match the rest of your dash since it appears various parts have faded and/or changed colors over the years.
I would need to double check my paint supply and make sure I actually have the extra vent valance panel.
Old Feb 4, 2024 | 08:27 PM
Thanks! I appreciate it! Let me know!
Old Feb 8, 2024 | 03:55 PM
Joe, I've looked at that chart and I guess I just don't understand how to get the correct colors for my particular car.
Old Feb 9, 2024 | 12:58 PM
rectifier's Avatar
Good luck matching interior trim.Even better luck getting it to adhere to the raw plastic.If it is raw plastic you will have to use an adhesion primer specifically for raw plastics,an up to date body shop will have that plastic primer/sealer and it will need to be catalized,as a fair amount of todays fascias come raw plastic and need a adhesion primer and then color applied.You may drop off your clean raw plastic parts and ask to have one light even coat sprayed,take them home then figure out what you are going to do for color.Once you get your paint dialed in,don't be afraid to carefully mask off a large area and blend your paint out so your eyes cannot pick up a color mismatch.
Andy
Apr 6, 2021 05:45 AM
Christophe2m6
Apr 30, 2015 01:44 PM
71OldsCool
Paint
19
Sep 26, 2014 08:35 AM
jmac69cutty's
Mar 11, 2009 12:04 PM
69convertible
Ninety-Eight
Dec 8, 2008 10:03 AM
