clear coat repair
Old July 11th, 2012, 12:53 PM
LI Olds's Avatar
clear coat repair
i am looking at a car that is nearly perfect in every way EXCEPT. the hood and trunk have clear coat peel due to sun exposure, the sides are shiny and nice... this car has a lot going for it, namely 30+ years of owner history and maintenance receipts and repairs..
is there a way to fix the clear coat issue without painting the car?
LI Olds is offline
Old July 11th, 2012, 01:56 PM
Registered Luser
ent72olds's Avatar
By peel, do you mean it has the texture of an orange"peel", or is it actually peeling? If it is peeling, must be stripped and refinished. If it has texture, it may be wet sanded and polished.
ent72olds is offline
Old July 11th, 2012, 02:08 PM
If the clearcoat has peeled it will need to be repainted. A lot of places can match and blend paint, so you won't have to paint tehe whole car.
oldcutlass is online now
Old July 12th, 2012, 12:48 PM
LI Olds's Avatar
I mean like peeled away.......sun fade........ I guess I could always have a paint shop paint the hood and trunk and fade it in
LI Olds is offline
Old July 12th, 2012, 01:02 PM
Rickman48's Avatar
No - the old clear must come off the whole panel, as the new clear will also delaminate if you try to paint over it!
Most shops won't guarantee it, as they don't know what brand paint is there, why it came off, or if their clear will be compatible!
Rickman48 is offline
Old July 12th, 2012, 01:18 PM
Chevy budget Olds powered
coppercutlass's Avatar
You will have to most likely have to repaint the whole panels. Since you have areas that are peeling as you sand the areas that are not cleared you will sand into the paint and creat a very uneven and not so good looking paint job. To do it right you must sand all of it down ., not to metal but to an even uniform finish as long as the paint is not cracked etc.. Then prime / seal/ base then clear. There is no quick fix for this to do it right and make it last you must do it right.
coppercutlass is offline
Old July 12th, 2012, 06:55 PM
Registered Luser
ent72olds's Avatar
If you bring it to a shop, let me know where...if it's one of my accounts, I can make sure it gets done properly.
Del70
September 30th, 2014 07:21 PM
Phoenixed
Paint
May 7th, 2011 01:58 PM
'S'tuff1979
June 9th, 2010 07:15 AM
Jamesbo
Paint
November 29th, 2009 12:14 PM
jensenracing77
Paint
33
July 30th, 2009 07:42 PM
Quick Reply: clear coat repair
