BOLTING DUAL GATE TO TRANS TUNNEL
Old Nov 3, 2009 | 03:48 PM
LIMEGREEN71's Avatar
'71 Convertible
I'm converting a factory column shift car to a Dual Gate with a console. Did the factory floor shifter, either Dual Gate or regular, bolt to the floor with a large sheet metal fastener, or was it a bolt with a nut welded in the underside of the transmission tunnel. Thank you so much for any experience with this!
Old Nov 3, 2009 | 04:00 PM
70 cutlass s's Avatar
They use a mounting bracket you can order a replacement. At Year One their about 105 bucks. You might also try the Parts Place.
Old Nov 3, 2009 | 09:28 PM
2blu442's Avatar
Dual Gate Hold down fasteners
It's been a few years since I pulled one from the floorboard, but I'm 99% sure it was sheetmetal type screws. Very similar to the ones that hold the bolt on center caps on SSII wheels. John
Old Nov 3, 2009 | 10:28 PM
svnt442's Avatar
^^^^^^^What he said. They just bolt to the floor.
Old Nov 4, 2009 | 04:11 AM
Ok yes if it already has the bracket on it and than use sheet metal screws. If got the complete shifter than it does.
kitfoxdave
Jun 6, 2011 07:02 AM
Olds92
Oct 25, 2010 09:05 AM
olds455
Jun 5, 2010 07:15 AM
BerBer5985
Jan 14, 2010 08:53 PM
