70 Supreme square mirror?!
Old Apr 30, 2012 | 07:36 PM
blleach's Avatar
I've got a 1970 Cutlass supreme... It has a single square mirror on the drivers side. It was recently broken off when being ran into in the garage and I can't find another one like it anywhere. Was this not original or am I just looking in the wrong spots? Also, the base of the square mirror is about 2 inches longer than the circular "original 70 mirror" that I just purchased and received from OPGI. Someone please help me out here or shoot me in the right direction. Thanks!
Old Apr 30, 2012 | 10:26 PM
stlbluesbrother's Avatar
Well, as far as I know in 1970 the Cutlass Supreme came with a chrome, oval shaped mirror on the driver's side. Here are pics
Also offered in 1970 were clamshell mirrors. IMG_1031.jpg So, the square mirror you mentioned must be from another car or different year. I'd go with the one you bought from OPGI.
Old May 3, 2012 | 12:40 PM
leroycjr's Avatar
Blleach,
I actually have that same mirror STL has in his post, I have a 70 convertible. I bought mine LONG time ago on ebay and just never put it on the car as I have been working on it. I too have seen the OPGI chrome ones that I'm thinking about purchasing too.
The only thing that is burning me with the OPGI ones is that fact that they are manual mirrors and dont have the door mounted remote. And my drivers side panel has the hole for the remote.
Old May 3, 2012 | 06:31 PM
blleach's Avatar
I've already bought the one from OPGI. I just wanted to keep it square if it was actually original. The bolts holes on the 2 different style mounts are compltely different. The OPGI mounting holes will have to be drilled out on the door and I don't want to do that if I can find a square mirror. Makes me wonder if the door isnt original or if some model of Cutlass could have actually came with a square mirror.
Old May 3, 2012 | 06:54 PM
Seriousfun's Avatar
*ssholes Garage
[QUOTE=stlbluesbrother;400238]Well, as far as I know in 1970 the Cutlass Supreme came with a chrome, oval shaped mirror on the driver's side. Here are pics
Attachment 44967Attachment 44968
do you know if pass mirror was available in the chrome?
Old May 3, 2012 | 10:20 PM
blleach's Avatar
OPGI offers a reproduction mirror for the passenger side. It is chrome and runs $49.95.
Old May 3, 2012 | 10:36 PM
Here's a picture of the driver's side door after removing the factory chrome mirror. I took this picture before mounting the 1970 clamshell style mirrors.
If yours doesn't look like this then it's possible you have the wrong door or someone modified the configuration in the past.
Old May 3, 2012 | 10:39 PM
No '70 Cutlass came with a square mirror. You should not have to drill out the holes in your door unless it was patched in the past, it uses a keyhole type of mount to attach it, where the mounting screws will go into the larger hole and slide into the slot, at that point it should be tightened with an allen head wrench.
Old May 4, 2012 | 03:01 PM
blleach's Avatar
Hmm... Thats kind of alarming! I bought the cutlass off of eBay and had to pick it up in Texas. The seller claimed it was all original but, the more little things I learn about them, the more I see they lied! Luckily I only paid $2500 for the car if anything "major" pops up. It looks and runs great. Odometer reads 36,xxx and title shows that to be actual. The vin, cowl tag, and engine numbers all matched up and I havent had a chance to search the transmission to see if it too is original. So, I guess now knowing this, the circular chrome mirror from OPGI is going on the car regardless of what was on it!
Old May 4, 2012 | 05:01 PM
rocketboy's Avatar
the mirror you are refering to came on chevelles, el caminos, and monte carlos from the 68 to 72 years someone probally just needed one and stuck it on your car. i have seen that alot people putting chevy parts on an olds most of the time its cause its cheaper and they have never had an olds before to know the difference lol
Old May 4, 2012 | 06:25 PM
Seriousfun's Avatar
*ssholes Garage
this is what my tin can looks like
this is what my tin can looks like, they made a pass.side one of these?
File Type: jpeg
Old May 4, 2012 | 08:04 PM
Replied to this on your other thread, but NO they didn't
Old May 5, 2012 | 05:43 AM
Seriousfun's Avatar
*ssholes Garage
I was hoping to find a pass. side to match
Old May 5, 2012 | 07:06 AM
Several vendors sell the passenger side mirror - blleach even mentioned one in this same thread.
Fusick sells them for $64.50
Old May 5, 2012 | 11:07 AM
If you're looking for a matching set of mirrors, why not go to the sport mirrors? They are remote left but manual right. But the outside appearance is identical.
The Stickman
Jan 13, 2010 12:17 PM
rtpassini
Dec 27, 2009 02:48 PM
stlbluesbrother
Dec 24, 2009 05:47 AM
panamracer
Jul 27, 2009 05:24 AM
Nailhead 88
Jun 3, 2008 08:09 AM
