65 442 vent window restoration
Old March 16th, 2014, 03:47 PM
rlm765's Avatar
Removed the vent window assembly in preparation for
Rechrome of all the chrome trim. I removed the handle. I want
To remove the glass. I see the two rivets...do you drill theses out in
order to remove the glass? If so, where do you get new rivets and is there a special tool to replace them. I did a search to see if they were avail as repo..guess they aren't. Thanks for any help.
rlm765 is offline
Old March 16th, 2014, 08:06 PM
Justin
oldstata's Avatar
Have you looked on bro442.com in his restoration tips?
I remember reading on the vent glass but not sure if it went into the details your looking for.
I know you can email him he usually responds in a day or two of email sent
oldstata is offline
Old March 18th, 2014, 09:24 AM
rlm765's Avatar
no I haven't check that site. I will now...thanks
rlm765 is offline
Old March 18th, 2014, 02:21 PM
rlm765's Avatar
After searching many sites I found the answer. it was actually on a GTO forum. The rivets can be removed with a small screw driver by lifting the head up enough to grab with a small vice grip....using counter clockwise motion, the rivet will lift out. The rivets are reused after replacing the glass. I just located this and will attempt to remove tomorrow.
rlm765 is offline
Old March 25th, 2014, 06:50 PM
Justin
oldstata's Avatar
Wondering how this turned out and if you can include pics as I will be doing this in the near future
oldstata is offline
Old March 26th, 2014, 05:10 AM
allyolds68's Avatar
Who are you using to have them re chromed and how much? Sandy's in Syracuse quoted me $325 for the 68 vent's which, I think, is much less to chrome than the 65's.
allyolds68 is offline
Old March 26th, 2014, 09:47 AM
rlm765's Avatar
I haven't taken the pics yet. I will try to do that this weekend. BRO442 wants to post them on his site. I don't know the cost for the rechrome yet. I should know by the end of the week. I am having all the pot metal chrome re-done so I think I am gonna have to get a second job!
rlm765 is offline
Old March 26th, 2014, 10:02 AM
therobski's Avatar
I just finished restoring mine on the 64 Pro touring car I'm building, I could not get the rivets to separate so I drilled them out. I think Ames has replacement rivets but I used two small screws, nuts and a little lock tight. I also bought their vent window rubber. As far as re-chroming, maybe I got lucky but I used fine steel wool and patience!
therobski is offline
Old March 26th, 2014, 11:06 AM
rlm765's Avatar
beautiful job! I wanted to replace the vent glass...I am going to try to polish my vent metal as well. I have the frame out to get chromed now. I got lucky I guess with the rivets..they came out with very little difficulty.
rlm765 is offline
Old March 26th, 2014, 11:50 AM
therobski's Avatar
I had to source two post doors out of NM, Thus, I have an extra pair of vent glass if you turn up dry up your way.
Old March 26th, 2014, 12:46 PM
rlm765's Avatar
Got the glass on order..but thanks a lot for the offer!
rlm765 is offline
Old March 26th, 2014, 03:29 PM
442scotty's Avatar
Let us know how the pot metal trim turns out and where you had it done
442scotty is offline
Old March 26th, 2014, 03:30 PM
Justin
oldstata's Avatar
Yes and before and after pic so we can judge on how bad pits are
oldstata is offline
Del70
July 21st, 2020 11:42 AM
84oldsDelta88
20
January 12th, 2016 01:36 PM
bobfo1
Body work
November 17th, 2013 06:40 PM
Tom442
July 23rd, 2011 01:17 PM
dynamic88
February 13th, 2008 06:17 AM
Quick Reply: 65 442 vent window restoration
