73 455
The 350 heads will physically bolt to a 455. All the interfaces and bolt holes are the same. Unfortunately, the SBO ports are much smaller than those on a BBO, which will create a mismatch and flow disruption at the intake manifold to head interface. Why do you want to do this?
I found a good deal on a 73 455 short block. I have a 73 350 in my car now with 7A heads with w-31 sized valves. I was just wondering if using the 7a heads would be an inexpensive way to boost the 455 compression ratio. I have heard of people putting big block heads on their small blocks just wondered if it would work in reverse. I guess not... If I was smart I would stop looking thru craigs list and KIJIJI. They give me bad ideas.
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
