Carb Size
Old Mar 24, 2015 | 08:25 AM
LoganMiller68's Avatar
Carb Size
Hello Everyone.
I was curious about what would be a good carburetor size for my build:
400G Block
Edelbrock Aluminum Performer Intake Manifold
C-Heads
Everything is pretty much to stock specs.
Obviously it doesn't really see much time over 5000RPM very often, however I do kick it in the butt every once in a while.
It's not a full race motor, but I do want something that will be a good balance of power and street application.
Thank you!
Old Mar 24, 2015 | 09:34 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
650-700 CFMs by the math. The original Q Jet was 750CFM.
Engine Size (c.i.d.) X Maximum rpm/3,456 = cfm at 100-percent Volumetric Efficiency (VE)
Example: 400 c.i.d. X 5500 rpm = 2,200,000/3,456 = 636 cfm.
But keep in mind this is at 100% VE. The argument could be had that 750 is too much. But thats what the factory spec was rated at and it worked just fine with the factory jet/rod set up
(Stock Engines VE = 0.75 - 0.85, Mild Built VE = 0.85 - 0.90, Racing Engines VE = 0.90 - 1.0)
You will do well with a 650-750cfm street carb from say Edelbrocks AVS series or a well tuned Q-Jet. Keep in mind most Qjets are 750cfm. The Ebrocks are very user friendly and can be tuned on the car with a rod/spring/jet kit. Tech support is great.
A properly tuned Q-Jet is hard to beat as well. And no throttle modifications needed.
Anything more than 750 the engine will be over carbureted causing drive ability issues.
There are other parts that can sway carb selection too such as intake design, head and cam design, converter stall, rear gears etc...but for the average mild street car the above math will be fine.
Old Mar 24, 2015 | 09:36 AM
If your going back to a Rochester then you'll get a max of around 750-800 cfm for stock. If your going to run anything else 750-780 is my rule of thumb for a BB. I think anymore than that would be over kill. For normal everyday driving a 650 would be adequate.
Old Mar 24, 2015 | 09:52 AM
Thanks for the info guys! I appreciate it!
Old Mar 24, 2015 | 02:27 PM
cutlassefi's Avatar
No less than a 780. I've done multiple 455's on the dyno, at 4000 and above they start pulling vacuum with 850's. What does that tell you. Forget the formulas, go bigger than what they recommend and take the time to tune it right. You won't be sorry.
Old Mar 25, 2015 | 02:00 AM
Oldsragger's Avatar
Does any know if a edelbrock 750 carb use much fuel, or is it the trottle response Who deside it if the carb use much fuel anyway if it big or small? im thinking on just cruising around wiyh carefull trottle respons. Or how big the engine is? Thinking more a stock/street engine.
I have a q-jet carb (i dont know what size it is) on a 307 and it use very low fuel as long im carefull with the trottle response.
I will use a 750carb on my g block too, with same setup as the first post says. But im thinking a BBo will use more fuel than a SBO anyway?
Old Mar 25, 2015 | 06:35 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Get your Qjet retuned or a Street Demon 750 if you want fuel economy for your 407. A lot of people have had issues with the Edelbrock 750 and it won't match the fuel economy of the carbs above.
Old Mar 25, 2015 | 07:39 AM
Oldsragger's Avatar
Ok, but the carb should work ok anyway? I mean, it should not be a bad carb? the carb have been on the engine from before when the engine was set up Some yrs ago, I Just do a gasket swap and clean it inside some weeks ago. About the economy, i Will try and find out.
if i will replace the carb i will go for a computer injection carb i guess.. Its expencive but maybe i will find economy and power with rigth setup. Like an modern injected v8, lol
Old Mar 25, 2015 | 10:28 AM
Computer injection? Wow ... technology!
Old Mar 25, 2015 | 11:26 AM
70cutty's Avatar
Beer Connoisseur
Not sure if you noticed that OP is from Norway. Sometimes things are lost in translation.
English is probably his 2nd or 3rd language. When looking at his posts, his english is better than half of the American people that post here.
Old Mar 25, 2015 | 12:19 PM
Originally Posted by 70cutty
... his english is better than half of the American people that post here.
True enough. Or better than my Norwegian, for that matter. I just thought it was a funny turn of phrase.
Old Mar 25, 2015 | 12:56 PM
Oldsragger's Avatar
Hehe, you know what i mean about computer carb? maybe EFI carb.. sorry bad explaination (was it right)..
like this i mean, just dont remember what it names, actually i like pump carbs best,and the oldschool way,,, but im just thinking about our gasoline prices these days so maybe its a good replacement if a guy want economy and power when he want it.. (unless you have a good normal carb with rigth setup then)..
If i fill up my gastank in our prices here for 95octan or 98oct (when i find it) it cost me about 128 U.S each time... maybe a little lesser.
the carb from this site cost 2010 U.S but i guess i will fill up my gas tank more than 15-16 times in the future,so i guess i can save some money if buy a carb like this in the future gasoline use i mean... just a tought from my side..
Link for infos
https://www.holley.com/products/fuel.../parts/550-405
Sorry LoganMiller68 for talking about this.
Old Mar 25, 2015 | 04:36 PM
It's okay. We knew what you meant.
Old Mar 25, 2015 | 04:46 PM
Ouch.
That would definitely inspire me to look into an overdrive transmission and a fuel injection setup.
Old Mar 26, 2015 | 12:56 AM
Seff's Avatar
I pay that much, and I daily drive my car. So far it's around 20 MPG.
Old Mar 26, 2015 | 08:13 PM
Backstrom's Avatar
Ouch.
Visiting Florida right now, and to tell you straight, you american guys don't know how much it hurts to fill up a tank in europe!
2.59 a gallon is a joke to us, with prices x3 at home!
And just to make it clear, our 95 & 98 equals to 91 & 93 over here.
And snow, fourbangers, taxes and my mother in law makes it even better....
Old Mar 26, 2015 | 08:18 PM
Yeah it's tough to complain about fuel prices compared to you guys overseas. However, nothing wrong with a fine American whine every now and then.
Old Mar 27, 2015 | 05:48 AM
Backstrom's Avatar
I'm not saying that the ebrock 750 is a bad carb, but i had one on my mild 461 w 4speed, and i put around 1 year of tweaking with rods and jets in that one. Never got i to run smooth in transit between idle and part throttle. Off it came and a rebuilt and recalibrated q-jet was installed. world of difference, runs a lot smoother. The edelbrock 750 sits on a shelf, and i think thats the best place for it.
Old Mar 27, 2015 | 07:30 AM
Oldsragger's Avatar
Hmm ok, Well i have 2 x 650 holley carbs too, but they need a rebuild anyway, but maybe they use a little more fuel than other carbs i have heard. They have manual choke too. Or i can ask my friend if he want to sell his holley doublé pumper carb.. But again i guess its not really economic choice,
im Just use the car in the summer thimes anyway so i can live with some fuel drinking that days.
Old Mar 27, 2015 | 10:59 AM
Oldwolf's Avatar
I agree, i had a holley, before, boughed a used edelbrock 1004 (edelbrock manufactured Q-jet) slapped it on attached fuel, trottle cable and so on. started it, run like a champ, diddn't even had to change the idle jet settings. Totally different engine. each spring when I take out, im surprised. Problems over.
Old Mar 27, 2015 | 11:11 AM
Backstrom's Avatar
Think you are confusing air/fuel ratio with cfm. It really shouldn't make a big difference between a correct calibrated 650 and a 800-850 in daily driving, wot of course is a different matter, and if you have a bigblock you'll need 800 cfm at least imo.
Old Mar 27, 2015 | 09:58 PM
taxes
Yeah, I have read about how much tax there is on gasoline in many European countries. Some taxes are as much as or more than the base price of the fuel.
Old Mar 28, 2015 | 12:36 PM
Oldsragger's Avatar
Hmm ok, so why they sell edelbrock carbs if they cant work as they should? I remember my friend have a edel carb on his 454 chevy and he have only problem with it, tryed to replace needels and stuff like that many times, he installed a holley doublé pumper and problem solved and the engine wakr up.
Im exited to try this 750 carb i have, cause i guess its setup allready for the engine, but i have only the dyno papers, no info about setup of carb or how it runs,but i will find out..
I have a q-jet and it works great, but its on a sbo, and its automatic chocke on it and does not fit the edelbrock intake i have on my bbo, only i know from specs that the edelbrock 750 is the carb that should be used with the 2151 performer intake.
But again, i Will find out how it will work when i will fired it up.
Ok, so the Cfm numbers is the size of air Flow in the carb? Not needle setup sizes? Maybe i have missunderstand something about it.
Old Mar 28, 2015 | 02:56 PM
Backstrom's Avatar
A #2151performer has dual patterns for both spreadbore and squarebore. The q jet on your 307 is at least a 750, maybe a 800, you can tell them apart by looking at the venturi castings from above. Google it, there is a lot of good info around.
What differs your qjet from a bigblock one is basically the opening angle on the secondaries. Put some money on this and you'll be a lot happier, unless its one of those newer electronic controlled ones, in that case you'll have some electric connectors on top of it in front of the primaries. Mine is from a '77 350 and is an 800, had it rebuilt and the secondaries modified, an adjustable power valve piston installed and runs very good with stock 350 jetting.
Old Mar 28, 2015 | 04:48 PM
Oldsragger's Avatar
My q-jet have no electric parts on it, only automatic choke, and i can only see its aviable to adjust the idle screw, and not fuel mixture if remember rigth.
But if its a 750 or 800, how can i know it will deliver fuel enought for the BBO? but anyway it have this heating thing, that goes down the exhaust crossover on the 307 intake, i cant use it on the performer intake.. maybe its possible to built it to manual choke?
I can try to google the number on the carb if i can find out how big it is.. here is a pic of it..
Old Mar 29, 2015 | 03:36 AM
Backstrom's Avatar
You can convert it to electric choke, mine is and works very good.
try www.carbguy.com. I would say the most competent carbrebuilder on this side of the atlantic, or Kents qjet, he made my last carb. It aint cheap, count on nearly 4000 sek if the throttle shaft needs new bushings, and it probably will. Any of these guys will tell you if your carb is a good start and take it from there. Pm me if you want info on Kents qjet.
Old Mar 29, 2015 | 09:33 AM
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
The primary venturi size for the 800 cf. is 1-7/32 in and 1-3/32 in for the 750. If you look down the primary venturi the 800 cf. model will be smooth all around while the 750 will have a raise area around.
Old Mar 29, 2015 | 01:04 PM
Oldsragger's Avatar
I can check inside the carb primary tomorrow and take pic, on that pic above, i see the 800cfm have an extra plate or something down there? It looks like, and the 750 have nothing, i see its darker there.. Do you mean that Who sticking out a little in the wall?
Old Mar 29, 2015 | 01:23 PM
Octania's Avatar
Yeah, that baby bump there
PS how is one supposed to measure the venturi ID- by what means? And, can we PLEASE FOR THE LOVE OF GOD AND ALL THINGS SACRED do that in mm or decimal inches like a digital calipers might read? Please and thank you. Fractions are so 19th century. A really bad idea since the advent of the machine age. Pointless.
How about this- it appears the larger venturi means a larger GAP between that wall with the bump and the OD of the booster venturi. How about we come up with a handy way of measuring this gap that anyone can easily perform? Such as, a drill bit of size x will fit into this gap readily on the 800 carb but not so on the 750 carb. Now that would be handy useful info.
Old Mar 29, 2015 | 04:07 PM
Navy P-3 FE (Ret.)
Ones bigger by approximately 1/8 inch
Old Mar 30, 2015 | 09:40 AM
  #31
Octania's Avatar
come here so I can smack you
How about 64/513"
yes, sixty four five hundred thirteenths of an inch.
Old Mar 30, 2015 | 12:34 PM
  #32
Navy P-3 FE (Ret.)
Smile
1 7/32 minus 1 3/32
39/32 minus 35/32
1.21875 minus 1.09375
equals .125
or 1/8
39/32 minus 35/32
4/32
1/8
Mines closer all kidding aside.
Point well taken in your post, yeah I could have been more clear.
Old Mar 31, 2015 | 06:27 AM
  #33
More than likely it is 800 cfm. Just get an electric choke coil from a late 70's to 80's chevy, it will fit right in. There is a lttle you can block with a tiny dab of jb weld behind your choke coil. If you buy one or two larger primary jet sizes, start one jet size larger, your carb should run fine, depending on your cam size. What duration is your cam?
Old Mar 31, 2015 | 08:28 AM
  #34
Oldsragger's Avatar
Ok, i Will look for an Electric choke convert if i find it.
I dont know what camshaft it is inside, i guess it is orginal, i have only this pic, can anyone see if this cam have orginal shape on the "heads"? Maybe hard to see.
Old Mar 31, 2015 | 09:39 AM
  #35
Octania's Avatar
If you can tell the specs of a cam by looking at the shape of the lobes like that...
I bow to you.
I am lucky if I can get the specs by examining the chamfers and notches [factory] or the PN stamp in the aft end [aftermarket].
Other than that, it's degree wheel time.
Old Mar 31, 2015 | 12:12 PM
  #36
Oldsragger's Avatar
Maybe i can see the nr on the rear of the camshaft if i stick a small mirror and light down the disturbutor hole? Im not sure now
Lol, Well the point was if the orginal cam have sharper lobes than a upgrade cam. But i dont know. In my engine build paper it stands nothing about cam replace or specs.
Old Apr 1, 2015 | 01:27 PM
  #37
Oldsragger's Avatar
Allright guys, here are the pics up in my carb, is it a 800 size maybe??
Old Apr 1, 2015 | 03:41 PM
  #38
Navy P-3 FE (Ret.)
I'll say yes.
Old Apr 1, 2015 | 03:50 PM
  #39
Oldsragger's Avatar
OK, thats good then, guess i should Just get an Electric choke and just swap it over the bbo And hope for just turnkey startup without any other problems. I dont wish to modify it if its not nessesary.. Maybe i need to take a gasket swap again, cause i can see the gasket are a little "wet" that part sticking out from carb..Im not sure if its normal. 2 yrs ago from last gasket replace. Will check the bolts if its tight enought again.
Old Apr 1, 2015 | 07:39 PM
  #40
johnnyjaws's Avatar
go with a 870 holly averger word listen or not but do it
