Edelbrock air gap manifold
Old May 11, 2014 | 10:22 AM
Stevec's Avatar
Went to install the alt brackets on the engine today and the bracket that bolts to the intake manifold will not line up!
Has anyone else encountered this problem?
If so what's the fix?
Thanks!
Old May 11, 2014 | 04:37 PM
Smitty275's Avatar
Engine Builder
I'd venture say that anyone who has ever installed an E'brock intake has encountered this problem. Slot the hole in the bracket is about all you can do.
Old May 11, 2014 | 04:41 PM
Stevec's Avatar
I fixed it! I took a grinder to it and mocked it all up and it seems to be be ok. Just gotta get it powder coated and it should be ok!
Thanks!
Old May 11, 2014 | 07:07 PM
442rocketdave's Avatar
Hey Steve how much room do you have between the air cleaner and the hood and what carb are you using?
Old May 11, 2014 | 07:09 PM
I am considering buying an air gap for my 69 and running a 950 holley so just wondering what clearance there will be if any, I have heard several people say they liked the intake and how much did it help you or did you notice a difference. Thanks Dave
cwb442
Dec 26, 2015 10:06 PM
crank shaft
Mar 29, 2014 12:48 PM
Bad68442
Nov 29, 2013 07:53 PM
Stevec
Sep 5, 2013 01:11 AM
Finn5033
Feb 13, 2013 03:35 PM
