Cam help
Old Sep 17, 2013 | 02:37 PM
foo's Avatar
foo
Cam help
I need help choosing a cam for my engine since I have little to no knowledge about them.
What im looking for is the engine to be a weekend/good day - drag/driver/fun
my setup so far:
-M22 trans.
~455bb bored .030
-E heads - Exhaust 1.624; Intake 2.063
-Pistons - ICON UEM-IC886KTD-030
-Stock "N" Crank
"subject to change" still to get setups:
-Edelbrock 2151 Intake
Old Sep 17, 2013 | 02:41 PM
cutlassefi's Avatar
Flat tappet or roller, I do both.
Old Sep 17, 2013 | 02:44 PM
foo's Avatar
foo
flat tappet
Old Sep 17, 2013 | 05:44 PM
cutlassefi's Avatar
Headers?
Gear?
Desired performance/idle?
Thanks.
Old Sep 18, 2013 | 02:35 PM
foo's Avatar
foo
you'll have to clarify for me this is my first build,
I will be going with headers if that's what your asking.
Are you talking about the trans gear, or rear end?
I'm basically trying to get it 400hp and up, not sure what a good idle rpm would be for street/drag.
as you can see im clueless
Old Sep 18, 2013 | 04:40 PM
cutlassefi's Avatar
Yes, rear gear.
Good, you stated your hp goals.
I'd do an Erson TQ50 hyd flat tappet cam. 228/235@.050 with .504 lift on both. That would give you a noticeable idle, great midrange power and work well with either the stock or aftermarket valvetrain.
Let me know if I can help. Thanks
Old Sep 18, 2013 | 04:44 PM
svnt442's Avatar
I miss the JB100 I had.....can you sat TORQUE monster?
Old Sep 18, 2013 | 04:49 PM
foo's Avatar
foo
Yes, rear gear.
Rear gears are 3 73s
Old Sep 18, 2013 | 05:23 PM
cutlassefi's Avatar
Erson TQ50.
Jmo.
Old Sep 19, 2013 | 01:06 PM
foo's Avatar
foo
I sent you a PM not sure if you got it
Old Sep 19, 2013 | 02:36 PM
cutlassefi's Avatar
Yes, yours and Randy's both. Pm'd you back.
67flamedcutlass
Dec 19, 2019 07:54 AM
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
66 Olznut
Mar 9, 2008 12:30 AM
