edelbrock carb question
Old May 29, 2013 | 12:21 PM
CrazedCountryRebel's Avatar
TalksToToads
Hi, I am having a problem with the edelbrock carb on my delta 88. Either the secondaries are not opening, or they are but it is not shifting down when they do. It is definitely not shifting down. Isn't there supposed to be a rod or something going down to the automatic trans? That's the way it is on my ford, it looks like I am missing something.
Old May 29, 2013 | 12:54 PM
droptopron's Avatar
delete
A Turbo 350 has a cable and a Turbo 400 has a switch on the gas pedal. What transmission do you have?
Old May 29, 2013 | 12:55 PM
TalksToToads
It is a turbo 400, so it goes to the gas pedal? I'm pretty sure it is missing I will take a picture. I found this http://www.summitracing.com/parts/bmm-20297 Is there a way I could hook it up to the carb so it would work in sync with the secondaries?
Old May 29, 2013 | 01:07 PM
Yes, that will work. Just follow the directions.
Old May 29, 2013 | 01:26 PM
TalksToToads
My camera decided not to work. If it goes to the pedal itself it is definitely missing, all that is there are the 2 stud things at the bottom and the rod with the wheel on it at the top, I will order that part and try to figure it out, thanks for the help guys.
Old May 29, 2013 | 02:00 PM
There are many ways to provide a switched wot 12v source to the trans. The stock locations varied based on model/year.
69CutlassAlex
Jul 30, 2013 08:18 AM
70Cutlass_408
Jun 24, 2011 07:55 AM
#1CutlassSupreme
May 14, 2008 04:28 PM
fearthisrocket
Feb 18, 2008 06:19 AM
Huron
Jul 9, 2007 11:56 AM
