Vent line used as fuel return
Old Apr 13, 2013 | 07:52 AM
1971viking's Avatar
Has anyone used the vent line to the charcoal canister as a fuel return? I read that it is too small (1/4 inch). I think I need 5/16.
Thoughts?
Old Apr 13, 2013 | 08:19 AM
I don't see why you couldn't, considering that the return on a return-type pump can simply be blocked and it will still work fine.
Old Apr 13, 2013 | 10:35 AM
1971viking's Avatar
Thanks. I will see how that works for me.
Old Apr 21, 2013 | 07:00 AM
1971viking's Avatar
Did not work. It pushed the fuel into vapor separator for the charcoal canister behind the rear seat. This conection was designed to stop liquid from flowing into the charcoal canister under the hood. 3 vent lines on the gas tank that hook up to the vapor separator. That goes into one line that goes to the front of the car.
It was designed to flow vapor from the tank but not flow the other direction.
Old Apr 21, 2013 | 09:53 AM
I thought that you meant that you would use the 1/4" line to connect the return port on the pump to the return port on the tank, not that you would just leave the 1/4" line connected to whatever it had been connected to originally.
Obviously, you can't push gas back through the vapor return system and expect it to work normally.
In the future, I will have to add a warning when discussing subjects like this that the line must be completely disconnected from the parts of the system it used to be connected to.
davepnola
Dec 2, 2010 09:00 PM
69Rman
Feb 26, 2010 05:10 AM
abram
Oct 26, 2009 07:53 AM
Flye
Jul 31, 2009 04:03 PM
68conv455
May 20, 2008 02:03 PM
