distributor
Old Feb 23, 2013 | 04:46 PM
jminor1961's Avatar
distributor
I have a distributor in a 394 that will not move or will not come out
the motor is out of the car. I want to remove and get the valley pan.
The car sat for 25 year in my garage I poured gas in the carb and it
started ran find but after I got it out I try to get the dist out and it
wouldn't move or come out anybody got any Idea
thank
JIM
Old Feb 23, 2013 | 05:24 PM
Octania's Avatar
Engine is out of the car?
no worries... assuming that the 394 is built much like a 455...
Remove oil pan
remove oil pump
tap oil pump driveshaft towards top of engine from below
Which should drive the distributor out. Have a soft surface under the distributor to catch it- or a helper.
you might have to remove the washers on the drive rod, or use adifferent rod of your choosing to tap the distributor with- not sure if the 394 uses an oil pump drive rod with washers or not.
chris83
Aug 18, 2012 01:47 PM
Oldsmobile Jo
May 30, 2010 07:58 AM
OLD SKL 69
Mar 30, 2007 07:33 PM
Sixoh
Feb 17, 2007 06:41 AM
<Tim>
Jul 17, 2003 05:06 AM
