455 Stroker....
Old Aug 18, 2012 | 01:04 PM
Stevec's Avatar
455 Stroker....
I have yet to to buy a crank and connecting rods mainly because I'm still not sure if I want to stroke this thing or not. I may go with a set of big valve c heads that I presently have because I really do like the look of the original engine.
My hp goals are 450-475hp on pump gas and good vacuum for my brakes,should I stroke this thing? How much more $ roughly will it take to do it as far as machining?
Old Aug 18, 2012 | 01:57 PM
hamm36's Avatar
I am no pro, but if you want 450+hp from a 455 you will need +$,$$$.00. If you want a fun driver, go stock w/some fun. Use a Edelbrock performer intake/650-750 cfm with w/z exhaust 2.5 H, or X pipes.
Old Aug 18, 2012 | 02:08 PM
Stevec's Avatar
This is the last motor I'm building for this car and I'm gonna do what I should have done the first time. I love my car but what it lacks is *****!
Old Aug 18, 2012 | 06:07 PM
cutlassefi's Avatar
Hey Steve,
If you're looking for 450-475hp go with aftermarket heads, a mild cam and an 800 or bigger carb. In fact you could probably make 450 with the cam you have and the good heads.
The more builds I do the more I believe using stock heads is a waste of time and money, especially on a big block.
Jmo
Old Aug 18, 2012 | 06:19 PM
Stevec's Avatar
I was thinking of reusing that cam, I kind of like the look of the factory heads but if I go with the edelbrock heads I'm somewhat limited when it comes to a fuel pump. I was thinking of using a RobbMc fuel pump.
I know what my goals are now all I need is to come up with a solid plan and buy my parts accordingly.
TORTUS
Oct 18, 2012 04:50 AM
smietana
Jan 15, 2012 08:35 PM
Wilson
Nov 22, 2011 04:52 AM
85olds442
Feb 3, 2010 12:03 PM
442 Jack
May 23, 2008 11:16 PM
