find the correct water pump
Old Aug 6, 2012 | 02:46 AM
EightballZ's Avatar
hey there,
can't believe that its such a PITA to find the correct waterpump for my lady.
i need a standard water pump for a car with A/C with a long snout and an overall length of 6.072" !!! (1970 olds toro GT)
any idea where i can get one of those? or at least you have any part numbers?
need that pump really soon....in germany
rockauto has only one water pump for car with A/C in stock...and thats the one with a short snout
thanks
kay
Old Aug 6, 2012 | 03:58 AM
Octania's Avatar
Well, sir, the 6.1" water pumps as far as I know all came with the 1.75" inlet nipple, and that combo is far and away the most common Olds V8 water pump on the planet. The typical casting number is 412265, with a large "4" on the RH outlet boss. I have dozens and dozens of used ones, or you can get a nice new one at any parts store. Ask for one from a 1976 Toronado. Pretty sure by 1973, almost all Olds had AC and all of the AC cars used the #4 WP. Beware the stamped impeller pc of crap vs the factory type cast iron impeller.
http://www.ebay.com/itm/Remanufactur...77a8c6&vxp=mtr
I can ship to Europe via USPS but it is very very expensive.
Old Aug 6, 2012 | 04:41 AM
EightballZ's Avatar
correct me if i'm wrong...but as far as i know..casting # 412265 means 5.95" in height.
the correct casting # for a 1970 toronado with 6.07" in height would be 404562
see:
http://www.oldsmobility.com/oldsmo/v....php?f=6&t=391
EDIT: well it looks like they have two different sizes for one casting number 5.95" and 6.07" ..i'm confused
Old Aug 6, 2012 | 08:27 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
see:
The difference of 5.95 and 6.07" is negligible.
There is a 5.1" , a 5.5" and a 6.1" pump.
Old Aug 6, 2012 | 08:32 AM
EightballZ's Avatar
yeah i see...thank you
Old Aug 6, 2012 | 08:59 AM
EightballZ's Avatar
so this pump will do it, right? its for a 1976 toro
http://www.shopping.com/54301260-pro...LrWUvNw==/info
Old Aug 6, 2012 | 09:02 AM
It looks correct in the picture, but you can get the pump for $12 on rockauto. Just look up 1980 delta 88 with the 5.0 307 engine. That will be the same as well.
Old Aug 6, 2012 | 09:08 AM
EightballZ's Avatar
ok ok...so i wanna order A-1 cardone #58295 via rockauto...
rockauto says this fits for some cars with A/C and on other cars only w/o A/C ...at least the hub height is ok "w/5 15/16" Hub Ht" ..so what means that thing with A/C??
Oldsmobile Toronado 1980-1973 Application Data:
w/A.C. and Standard Pump and w/2 Outlets
Oldsmobile Toronado 1978-1970 Application Data:
w/o A.C. and Standard Pump
http://www.cardone.com/Products/Prod...d=58295&p=rock
can i order that pump??
Old Aug 9, 2012 | 12:36 PM
EightballZ's Avatar
rockauto has a problem with that...they wanna tell me that a pump for a 307 made a decade later could never fit on a 1970 455.
so i guess you guys are right?...hopefully
jensenracing77
Jan 27, 2015 03:41 PM
jozw30
May 7, 2012 06:48 PM
ddx77
Jan 16, 2012 08:08 PM
ROCKET VAPOR
Dec 7, 2010 03:15 PM
72Ctlss
Jun 23, 2009 03:12 PM
