455 fitting 66 cutlass 4 door
Old Dec 3, 2011 | 09:30 AM
cintr113's Avatar
I'm just picking up a 455 big block... right know i have a small block in there.. my question is other then the headers what else do i need to do to put this motor (F396021 with g heads) in there. Will i have clearance issues anything i need to move around... Can some tell me what i need to look out for???
Thanks in advance for the responses..
Old Dec 3, 2011 | 11:02 AM
svnt442's Avatar
Well I can tell you use the same mounts that are on the 330 and the water pump, brackets and pulleys as well. Not sure about any clearance issues as you could get a BBO in that car soo....
Old Dec 3, 2011 | 11:18 AM
should drop right in!
Old Dec 3, 2011 | 11:49 AM
cintr113's Avatar
The car has a 283 chebby small block do i have to get different mounts to drop it in?? what kind of headders did you get for yours
Old Dec 3, 2011 | 11:53 AM
gearheads78's Avatar
car guy
You will need the correct 64-67 Olds frames mounts and you should be good to go after that.
Old Dec 3, 2011 | 11:58 AM
cintr113's Avatar
Thats sounds great... This engine came complete with everything.. someone mention to change all the brackets and stuff... should i do this or leave it all it came with and freshen it up....
Old Dec 3, 2011 | 12:06 PM
doc's Avatar
doc
I'd be interested in the chevy mounts when you get done....
Old Dec 3, 2011 | 12:07 PM
svnt442's Avatar
You're also going to need a different transmission and most likely driveshaft.
Old Dec 3, 2011 | 12:08 PM
Sorry did not realize you had a 283 in it?? As the others said, you need the correct frame brkts and motor mounts for the 455. If yours has all the accessory's and brackets just use those!
What trans are you currently using? The chevy trans will not work directly with the olds motor? I believe your starter wiring will have to be rerouted to the other side also.
Old Dec 3, 2011 | 12:17 PM
cintr113's Avatar
This setup came with the 455 motor and 400 trans together and i also got the yoke for it and the radiator... Just pulled from a working car...
Old Dec 3, 2011 | 12:20 PM
Then it should be rather easy!
Old Dec 3, 2011 | 12:32 PM
cintr113's Avatar
Im just tring to see what i am facing to see if i needed to look out for something from everyone's else experience...
Jaybird's Avatar
cintr113: This sounds like a great project! I don't have anything else to add except to say, we would love to see some pictures!
Good luck with your engine swap.
Old Dec 3, 2011 | 12:49 PM
cintr113's Avatar
Thanks i will post before and after pictures...
im considering to do some sprucing up... and take it apart before i put it in so i can get more power out of it.... will keep all of you posted
Old Mar 14, 2012 | 06:47 PM
cintr113's Avatar
Ok I'm ready to do the rebuild.. I want to do something a little better then stock.. Something like mlld. Nothing to crazy.. Not too much money either but will do what makes sense. Please give some suggestions so I can resaearch and make a decision on the recommendations. Thanx
Old Mar 15, 2012 | 07:08 AM
There are several threads related to mild to wild 455 builds in here! Even just a stock 455 with that trans, a set of headers, good carb and manifold, will be a dramatic improvement over what you have now.
Old May 25, 2013 | 05:48 PM
cintr113's Avatar
Ok project is finally almost done pics are coming soon. I have a question. What headers should I get for this setup. Thanx
Old May 25, 2013 | 07:30 PM
Cool, fill us in on what you did, and would love to see some pic's. Any brand header should work well with your 455.
Old May 25, 2013 | 07:42 PM
cintr113's Avatar
Yes but I hear that most of them don't fit right on the 1966 f85. Any suggestions
Old May 25, 2013 | 07:49 PM
edzolz's Avatar
Buy Hookers that fit a 66 442.
Old May 25, 2013 | 07:57 PM
cintr113's Avatar
Does it make a difference from a 4 door to the 2 door. Because I have a 4 door. Do you have a model number from hooker by any chance
Old May 25, 2013 | 08:01 PM
The passenger side sometimes needs a bit of massaging sometimes with any brand. Does not matter about how many doors the front is the same.
Old May 25, 2013 | 08:12 PM
cintr113's Avatar
Thanx. I will post pics and tech info soon
Old May 25, 2013 | 09:44 PM
lemoldsnut's Avatar
If you need the frame side of the mounts I have those available. Also can do the Chevy mounts for whoever was looking. Just drop me a pm or email
thanks
Larry
lemoldsnut@aol.com
CutlassS1972
Oct 30, 2014 06:19 AM
projectheaven
Dec 30, 2011 04:47 PM
rcdynamic88
Feb 19, 2010 08:56 AM
fjross
Dec 8, 2009 07:59 AM
Olds Nut
Sep 18, 2007 07:10 AM
