1970 442, 455 engine
I have a 1970 442 with 455ci engine, # 7 piston is not working. i pulled the plug, connected the dist wire to it........got great spark, put it together, started the engine......pulled the wire and still no change in the engine...........could it be a bent valve?
Joe
i have 1970 olds 442 with 455.........#7 piston is not firing
Joe
I never heard it on the engine I just pulled out of my car...had 2 flat lobes on #5 cylinder. And they were F-L-A-T!
Before I knew they were flat, the car still ran 13.50 shifting at 4500 rpm. It wouldn't rev any higher because of that. Pretty strong motor to do that...
BeenThere
August 26th, 2014 12:03 PM
