1970 442, 455 engine
Old Sep 24, 2011 | 05:40 AM
my442conv's Avatar
I have a 1970 442 with 455ci engine, # 7 piston is not working. i pulled the plug, connected the dist wire to it........got great spark, put it together, started the engine......pulled the wire and still no change in the engine...........could it be a bent valve?
Joe
i have 1970 olds 442 with 455.........#7 piston is not firing
Old Sep 24, 2011 | 05:50 AM
cutlassefi's Avatar
Do a compression check.
Old Sep 24, 2011 | 08:09 AM
442Harv's Avatar
Probley more like a broken valve spring. Like the other post said, give it a compression check.
Old Sep 24, 2011 | 07:17 PM
ah64pilot's Avatar
Compression check, sounds like a flat lobe to me...if spring was broken the valve would fall and MIGHT hit the piston depending on how far it fell.
Old Sep 25, 2011 | 06:02 AM
cutlassefi's Avatar
True, but with a flat lobe you'll normally hear tapping, he didn't mention that.
Old Sep 25, 2011 | 03:36 PM
ah64pilot's Avatar
I never heard it on the engine I just pulled out of my car...had 2 flat lobes on #5 cylinder. And they were F-L-A-T!
Before I knew they were flat, the car still ran 13.50 shifting at 4500 rpm. It wouldn't rev any higher because of that. Pretty strong motor to do that...
BeenThere
Aug 26, 2014 12:03 PM
805cut
May 3, 2012 08:11 PM
my442conv
Nov 6, 2011 12:53 PM
my442conv
Oct 24, 2011 08:03 PM
charlierogers
Oct 14, 2011 09:44 AM
