455 engine wanted for 1970 442
Old Oct 5, 2011 | 01:42 AM
my442conv's Avatar
looking for a 1970 455 engine for a 70 442
Old Oct 16, 2011 | 09:13 AM
brian ashing's Avatar
call me 612 385 8875 have 455 in a 1968 olds 88 delmont 113000 miles runs good
Old Oct 16, 2011 | 10:18 AM
2blu442's Avatar
A few more details would help you get more responses. First I'm moving this to the parts wanted section for you rather than the parts cars wanted.
Then if you'd post your city/state as shipping an engine can get spendy quick.
Finally, are you looking for a complete engine with 1970 castings or would any 455 block work? You could add the E heads and correct casting intake, carb, distributor, etc. later
John
Old Oct 16, 2011 | 03:51 PM
Paladin31's Avatar
I have a 455 from an SX early 1970 build, so it has a two barrel carb & intake with E heads. Am near Kalamazoo Michigan, price negotiable dependent upon how much of the engine you wantlet me know. Thank you
Old Oct 18, 2011 | 05:43 AM
507OLDS's Avatar
Where are you located?
Old Oct 24, 2011 | 08:03 PM
omegasman1978's Avatar
Olds 455
I just thought I would let you know I have a Olds 455 that has been totally gone through. The block has been taken to a machine shop and cleaned or boiled. Then each pistion wall has been bored out .30 over also. Right now the block is setting on a engine stand with the camshaft, crank, pistsons, and timing chain assembled to it.
The heads have also been cleaned and bored out also for more air flow. the springs and valves are assembled to them as well. The rest of the parts and gaskets are still in the boxes that I purchased them in as well as the the Eldebrock 21511 intake peformer manifold too. Finally I have a Turbo 400 automatic transmission and converter to finish it off. I really would like to get $1300.00 if I could, but the price can be negotiated. Write me back if you have any other questions.
Thank you for your time and good luck,
BeenThere
Aug 26, 2014 12:03 PM
805cut
May 3, 2012 08:11 PM
my442conv
Nov 6, 2011 12:53 PM
charlierogers
Oct 14, 2011 09:44 AM
my442conv
Sep 25, 2011 03:36 PM
