72 Cutlass S 350 to 455 swap intake question.
Old August 17th, 2011, 10:46 AM
Al2011's Avatar
Hello everyone. Thanks for all the help so far. I'm getting things done slow but I'm still moving. The main thing slowing me down is getting information to get things right since it's my first Olds car. Question is, after I drop the 455 in using the 350 frame mounts and engine mounts is it true I will have clearance issues with a aftermarket intake and carburetor? My hood is the original hood. I was looking at either the Edelbrock RPM Air Gap intake or the Performer. The carb will most likely be a edelbrock 750 - 850 cfm 4 barell. Also what headers will work with my car and the 455 upgrade? 72 Cutlass S. Thank you all for being there during my learning process, you guys are the best!!! If you guys have a good intake and carb combo for a weekend car let me know. The car will never see the track and the motor I picked up is a 72 block with Ga heads. No history on the motor but before I bought it, was in a classic ford F-150 and it sounded healthy. My guess is the block is either original or has a stock rebuild but it's just a guess. Open to any suggentions..
Al2011 is offline
Old August 18th, 2011, 01:02 AM
svnt442's Avatar
The engine sits in the same place with the 350 mounts as it would with the 455 mounts. There will be no issue with hood clearance with an aftermarket intake...been there, done that.
Just get headers for a 455 and you're set.
svnt442 is offline
Old August 18th, 2011, 07:37 AM
NOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!1
Any clearance issues will be only due to the intake, carb, and air cleaner that you select and have nothing to do with your choice of motor mounts.
joe_padavano is offline
Old August 18th, 2011, 08:54 AM
Al2011's Avatar
Thanks for the replies. Then my next question is what is a good carb and intake combo that's proven to work with my car and the hood can shut? Good street performance too.
72 Cutlass S
Al2011 is offline
Old August 18th, 2011, 10:10 AM
Rickman48's Avatar
The air-gap will fit, but a air cleaner won't.
The performer is a good choice, and a 3310-2 Holley 750 works well, too!
Re-jet the carb, and re-curve the distributer for optimum HP!
Rickman48 is offline
Old August 18th, 2011, 12:52 PM
Al2011's Avatar
E-brock Performer manifold.
Somewhere on this site I can't remember the thread but they said the performer flows the same as the iron stock manifold, only difference it's lighter, is this true? I want my bolt ons to make more power than stock. What do you think?
Al2011 is offline
tinner
April 5th, 2015 07:43 AM
eurojeff
November 22nd, 2013 07:23 PM
curvewrecker
May 31st, 2013 09:25 AM
svnt442
July 17th, 2011 04:43 PM
car_designer
July 18th, 2010 04:55 AM
Quick Reply: 72 Cutlass S 350 to 455 swap intake question.
