Spark plugs and gap
Old August 17th, 2011, 05:59 PM
ziff396's Avatar
Spark plugs and gap
So, I thought I would replace my spark plugs in my 455 from champion to ngk. Engine ran fine before, however, I wanted to try the ngk's with a little less gap.
455, 9.7, edelbrock heads, hei, headers, voodoo 60803 etc.
I ran the champion RC-12yc @ .44. So I installed the new ngk's BCPR5ES that cross referenced as the same gapped @ .35.
It run's fine, but it idles like crap and seems rich (lean?) Instead of just a lope, it now like vibrates the whole car.
Just would like some input before re-gapping or putting the old ones back in.
Thanks Again
ziff396 is offline
Old August 17th, 2011, 07:37 PM
Why would you run such a small gap with HEI?
MDchanic is offline
Old August 17th, 2011, 08:28 PM
Redog's Avatar
I think the biggest problem is those crappy $7 a piece plugs.
I NEVER had any luck with anything other than the correct ACDelco plug in any of my GM cars
Redog is offline
Old August 17th, 2011, 09:12 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
If the car shakes, you're probably only running on 7 cylinders.
Pull the wires off the plugs 1 by 1 and see if the engine shudders. If it was firing correctly, it should shudder.
If no difference, that was the one not firing.
.035 gap is good in my opinion. I run .035 with an msd6al box on my car. Also runs a faster et with ngk plugs over the delcos.
J-(Chicago) is offline
Old August 17th, 2011, 09:59 PM
ah64pilot's Avatar
I would run the NGKs at .045" gap. And spark plugs won't make it idle funny, you've got one plug wire incorrectly seated. Most likely, it's the #8 plug wire against the A/C box...if the car has A/C.
ah64pilot is offline
Old August 18th, 2011, 04:33 PM
ziff396's Avatar
No AC. I checked all the wires today. No problem. So I pulled each plug, all were firing, and gapped them @ .045. Now she's happy again, and idles the same as before the change. I don't know, but I'll leave well enough alone.
ziff396 is offline
Old August 18th, 2011, 04:35 PM
ah64pilot's Avatar
I'm good for something around here You're welcome, lol!
DYSKIE
April 1st, 2015 08:21 AM
convert69
September 6th, 2012 06:26 AM
FL1970442
February 9th, 2010 07:45 AM
ChrisM
March 7th, 2009 08:07 PM
ChrisM
November 1st, 2007 02:23 PM
Quick Reply: Spark plugs and gap
