Oil Filter Stuck
Old Aug 14, 2011 | 11:23 AM
72 Olds Project's Avatar
Oil Filter Stuck
Well everyone, I went to change my oil after the break in time and now the stupid filter is seized on there. I tried everything. Even pulled the adapter off and put everything in a vice. Cut the filter off and tried tapping the end of with the filter holes. That thing is STUCK. Anyone have any suggestions or does maybe anyone have an extra oil filter adapter?
Thanks!
Wayne
Old Aug 14, 2011 | 11:35 AM
GAOldsman's Avatar
"Car"mudgeon
Put some heat on it now that it is in the vise and it should come right off.
Old Aug 14, 2011 | 11:38 AM
Thanks GA...I may have to take it somewhere as I do not have a torch. Go figure I just hope I didnt mess it up trying to take the filter off. I was careful of the mating surface to the block.
Old Aug 14, 2011 | 11:55 AM
boondocker's Avatar
Where were you in '72?
Whenever I have a stuck oil filter, I stab a big screwdriver through it and turn...never fails.
Old Aug 14, 2011 | 12:00 PM
OLDSRALLYE350's Avatar
Pull a part on patterson ave in winston my have one on a 1983 delta 88 they are open till 5:30 will have to take you own tools should be dirt cheap.
Old Aug 14, 2011 | 12:04 PM
Yeah I tried with that after the 1st failed attempt. 3 holes later it was still stuck. I even took my pry bar to it and it would not even budge. I think paint got on the threads and it really stuck it on. I know I oiled the top of the filter before putting it on and I only put it on hand tight.
Old Aug 14, 2011 | 12:40 PM
If you had wet isocyanurate paint on the threads, then you might as well have crazy-glued it on.
Heat will be your friend here. Go out and drop $20 on a Bernz-O-Matic torch. You'll be glad you did.
Old Aug 14, 2011 | 06:43 PM
ah64pilot's Avatar
My MAPP torch is the best thing I got out of plumbing for 5 years...works like a charm.
defiant1
Aug 26, 2011 09:45 AM
J'ville
Jul 10, 2009 03:18 PM
