455 engine swap
Old July 23rd, 2011, 08:18 AM
wagonmaker's Avatar
455 engine swap
Will any year 455 olds engine bolt up to a 1977 olds cutlass supreme ?
wagonmaker is offline
Old July 23rd, 2011, 09:08 AM
Yes.
MDchanic is online now
Old July 23rd, 2011, 09:26 AM
Rickman48's Avatar
Final Answer???
If it had a V8!
Provided your trans and rear end can handle double the torque!
Rickman48 is offline
Old July 23rd, 2011, 09:53 AM
svnt442's Avatar
The bottom end on all modern Olds V8's (260-455 from 64-90 excluding the 64 394) are dimensionally the same so an engine swap is easy as pie.
svnt442 is offline
Old July 23rd, 2011, 10:37 AM
Change the transmission as well, they lightened the drivetrain in '77, and the trans won't take the torque. Cracked two trans cases on my '77 350 by just putting it in reverse.
1969w3155 is offline
Old July 23rd, 2011, 11:33 AM
Originally Posted by Rickman48
Final Answer???
If it had a V8!
Good point! The 77s had the Buford V6 as an option. The frame mounts are completely different.
joe_padavano is offline
2blu442
February 3rd, 2012 05:05 PM
oldsmobum
January 14th, 2011 10:10 PM
citcapp
June 7th, 2008 05:37 PM
Olds71suprema
May 10th, 2008 04:57 PM
Retrorocket88
March 1st, 2007 06:22 AM
Quick Reply: 455 engine swap
