Engine swap, 455 to replace 394 in 1962
Old Apr 25, 2007 | 05:30 PM
2blu442's Avatar
Hi All
I'm talking with a guy online who would like to upgrade his 1962 Olds by putting a newer engine and trannie in it. Has anybody here transplanted a 330-455 plus TH350 or TH400 into a car that came with a 394? Can you share your thoughts about the transplant? Easy, hard, impossible? He's got a nice car and I'm sure he doesn't want to cut it up making the swap. I've got several motors and trannies I could sell him, but I don't have the background to share if this is really a swap that he wants to do. John
Old Apr 25, 2007 | 09:18 PM
88 coupe's Avatar
Junior Member
Originally Posted by 2blu442
........ who would like to upgrade his 1962 Olds by ........
Many would not consider it an upgrade, myself included.
394 has one front mount under the crank pulley, and two rear mounts, one on each side of the bellhousing.
Brackets will have to be fabricated from the frame to the 455 engine mounts, along with a crossmember for the single rear mount at the 400 tailshaft. If the ‘62 trans is the same length as a real Hydro and TH400, the driveshaft should fit, as is.
A body headers should fit with a couple of modifications
Early water pump, with the inlet on the left, is all that’s needed to use the stock radiator.
Unless I forgot something, the rest is a basic swap.
Norm
Old Apr 25, 2007 | 09:57 PM
Originally Posted by 88 coupe
M
All Toronados with longitudinal V8 drivetrain (1966-198?) use a single front mount under the pulley. There are two styles of bracket. The early bracket bolts on using the front cover bolts. The later bracket bolts to the side of the block. That should make the front mount easy. Even the 307 brackets will bolt to the 455.
Old Apr 26, 2007 | 04:41 AM
Oldsguy's Avatar
Past Administrator
I have also seen aftermarket and/or personally fabricated front mounts which are basically metal plates which are an extension of the front timing chain cover, well, actually I think they share some of the same bolt locations. I don't know about their feasability at all in this application however.
Old Apr 28, 2007 | 03:08 PM
88 coupe's Avatar
Junior Member
Originally Posted by Oldsfan
This car:
has a 455/THM400 combo ........
It's not unusual to see similar conversions at any of the Nor-Cal Olds Club meets. All I've seen, were done the same as described in the second post, which is how I did mine. Exception is, that some did not use headers, I did.
........ So its obviously possible ........
Not only possible, it's about as basic as it gets. The second post stated as much.
........ How easy it is, I don't know ........
On a scale of 1 to 20, 20 being a 455 into a Corvair and 0 being a 455 into a "G" body, it would be about a one.
Norm
Old May 1, 2007 | 07:58 AM
64Rocket's Avatar
I used a "JC Whitney" universal engine mount. It is a tubular banana shape bar with mount ears for the thru bolt type 455 or 350 OLDS mount. I fab my own trans cross member and used a stock trans mount. I like the support in the middle of the engine and on the trans. I dont like the front mount and there is no place the support the engine in the middle on a late model engine.
The universal mount was a cut and weld or you could drill and bolt in. All this was for my '50 coupe, but the '62 is almost the same. Should be easy swap.
I looked on "JC Whitney" and the uni mount only list for chevy but will work the same.
Geno
Old May 1, 2007 | 08:15 AM
64Rocket's Avatar
I just check on "trans dapt" performance products. They have the one I used.
go to engine swap kits and then universal mounts. The picture of the #4840 is what mine look like. Use # 9587 kit and fab your own trans cross member
Geno
http://www.tdperformance.com/TransDapt.html
Old May 1, 2007 | 08:01 PM
2blu442's Avatar
Thank you to everybody who replied to this message. I'll pass on the info and let Robert decide what to do next. He lives in Sacramento so one of you guys may be closer than me and able to sell him an engine/trannie to use.
John
Old May 1, 2007 | 08:38 PM
64Rocket's Avatar
John
I'm a 100 miles from Sacramento. I can maybe help some what.
Geno (510)-499-9235
Old May 1, 2007 | 08:41 PM
2blu442's Avatar
Thanks Geno!
I just emailed your message to Robert.
John
Old May 2, 2007 | 07:47 PM
Jakespeed63's Avatar
True Rocket Power
Hey Fella's, sounds like I'm too late and also that I think too :Old Skool/traditional.....Leave the 394 and get a 700R4 adapted to that engine. Hot Rodders are scouring swap meets and barns to get ahold of these true Rocket engines. It cost me allot of dough to rebuild the motor in my Starfire, but I wouldn't have it any other way. Saving my pennies and dimes to retrofit a 700R4, under my workbench, into the Olds.
Ross Machine will shave the case and provide adapters. PM me for the info or jaytee43@earthlink.net.
later, gotta get back to The HAmb (www.jalopyjournal.com)
JT
P.S. What is the story on his old engine? Worn out? Cracked block???
Old May 3, 2007 | 05:15 AM
Oldsguy's Avatar
Past Administrator
Ahh, I see we have another HAMBer here at ClassicOlds. Jake, I am working on my '48 trying to get the 455 in it and running. Going to a swap meet this Saturday for go-fast parts.....
Old Nov 6, 2008 | 04:40 AM
NAS Backyard's Avatar
New here, good to know this info is out here. I got a 455/400 with this car, may use it later, trying to get the original stuff running.
Old Nov 21, 2008 | 12:31 PM
KQQLCAT's Avatar
I see no one mentioned that the transmission tunnel will have to be cut and enlarged.
Pat
Old Nov 21, 2008 | 06:11 PM
citcapp's Avatar
The modifications to install a 455 and a Turbo 400 transmission should be similar or the same as the swap I did on my 1957 see 455 engine swap by citcapp in this thread it is very detailed
Old Feb 3, 2012 | 01:48 PM
Dean Eechaute's Avatar
I'm looking to install a 425 motor in my 64 88 convertible. Do you have some pics of the installation you did on yours? I got the engine mocked up where it needs to be but using the center mount holes looks like a custom crossmember would get into the angle part of the frame just aft of the were the original crossmember is. I don't have much wiggle room for the exhaust with the steering box located where it is. I do have a S manifold with a heat shield that will work on this combo for dual exhaust. Dean
Old Feb 3, 2012 | 05:05 PM
SBORule's Avatar
That's a neat looking Oldsmobile and it one of those model's you rarely see.
That would make one nice looking Pro/Street car.
jcdynamic88
Feb 21, 2015 03:33 PM
AHolden
Jun 28, 2013 12:57 PM
Ralph Mack
Feb 17, 2013 08:08 AM
Jody Karls
Oct 27, 2008 09:02 AM
