Question about Ga heads
What's the difference between 72 ga heads vs. 68-69 c heads? How can I tell if the ga heads are from a W-30? I've read on COTech section that is was a w30 but didn't have large valves. Someone please clarify........
Others will chime in on this I'm sure.
Terry
This is where I saw the w30 info...http://tech.classicoldsmobile.com/43.shtml. Casting#409100. Stating w30s. Hardly any were big valves if any at all.
I have several sets of GA heads, and iirc the small valve heads had 45 deg seat 2" intakes and 30 deg seat 1.68" exhaust valves. The large valve heads had 30 deg seat 2.07" intakes and 45 deg seat 1.63" exhausts. The latter heads should also have pressed in hard exhaust seats. All the GA heads ( and E and G heads) have "ramps" in the intake port floors while the A,B,C heads have the floor dropping right to the seat. The 70 up heads also have lowered intake port roofs to allow for valve rotators which lower the valve spring seats for a taller spring installed height.
