Question about Ga heads
Old Nov 14, 2010 | 08:47 PM
dre's Avatar
dre
What's the difference between 72 ga heads vs. 68-69 c heads? How can I tell if the ga heads are from a W-30? I've read on COTech section that is was a w30 but didn't have large valves. Someone please clarify........
Old Nov 14, 2010 | 09:09 PM
vette442's Avatar
Large valve Ga heads were used on 1972 W-30s (X code) and 1972 455/M20 4 speed (V Code cars). That's only approximately ~1,600 cars total. Not sure about Toronados. All other 1972 455 applications used small valve Ga heads. I need to dig up my specific info but the valve angles were different on the large valve heads too. As far as external identification, there is a debate that the three "ribs" on the casting of certain Ga heads possibly indicates that they are large valve heads, but I don't think that was ever proven conclusively.
Others will chime in on this I'm sure.
Terry
Old Nov 14, 2010 | 09:31 PM
dre's Avatar
dre
This is where I saw the w30 info...http://tech.classicoldsmobile.com/43.shtml. Casting#409100. Stating w30s. Hardly any were big valves if any at all.
Old Nov 15, 2010 | 03:35 AM
dre's Avatar
dre
If vie got small valve ga heads and plan to get a valve job to mark them large valves, wkd it matter if I were to get c heads with large valves even if they have to have machine work done?
Old Nov 15, 2010 | 09:38 PM
Run to Rund's Avatar
I have several sets of GA heads, and iirc the small valve heads had 45 deg seat 2" intakes and 30 deg seat 1.68" exhaust valves. The large valve heads had 30 deg seat 2.07" intakes and 45 deg seat 1.63" exhausts. The latter heads should also have pressed in hard exhaust seats. All the GA heads ( and E and G heads) have "ramps" in the intake port floors while the A,B,C heads have the floor dropping right to the seat. The 70 up heads also have lowered intake port roofs to allow for valve rotators which lower the valve spring seats for a taller spring installed height.
Old Nov 16, 2010 | 08:14 AM
I've never seen a factory pressed-in hardened seat. I thought all the factory hardened seats were induction hardened.
Old Nov 16, 2010 | 08:42 AM
Joe, please see p. 6B-16 of the 1972 fsm for verification that those heads indeed had pressed in exhaust seats.
Old Nov 16, 2010 | 12:07 PM
Thanks. The 1972 CSM is one hole in my collection.
Old Nov 16, 2010 | 09:05 PM
Texas Jim's Avatar
Texas Jim
So what about the '71 G heads, induction hardened or pressed in?
Old Nov 17, 2010 | 07:34 AM
Acc. to 1971 fsm, 442 and Tor have seats and bigger intake valves. however, no 1.68" exhaust valves; all 455s have 1.625".
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
