1969 400 Pistons
Old Aug 30, 2010 | 04:14 PM
501Paratrooper's Avatar
1969 400 Pistons
Any suggestions on where to get pistons for my 69 400 G block?
I will be using Eagle Connecting rods 6.735 so I will need floating pins.
Old Aug 30, 2010 | 05:06 PM
442Harv's Avatar
Try Mondello, Egge, Or Kanter.
Old Aug 30, 2010 | 05:10 PM
Run to Rund's Avatar
Sonic test the block. If it will bore to 4.00 you can use 327 Chevy pistons after bushing the rods down to.927" If you pick wisely, they will save a couple hundred grams (easier on rods and bearings), give you rings with less tendency to flutteriing (1/8 vs 5/64), and remove the pin offset. Don't deck the block until you see how far they are below deck.
Old Aug 31, 2010 | 10:02 AM
Texas Jim's Avatar
Texas Jim
nice advice. the 455 is the same way, you can use different mfg. components, works well, come out cheaper. thank GOD for good machinists.
Old Aug 31, 2010 | 03:51 PM
Thanks for info I'll get w/the machinist regarding the sonic test if not Egge it is.
stonecad
Feb 11, 2014 05:25 AM
getawaycar
Jul 13, 2011 05:13 AM
madwagon56
Jun 17, 2011 05:11 AM
66-3X2 442
Jan 19, 2011 12:14 PM
69442
Aug 6, 2010 05:03 AM
