Any benefit
Old Aug 30, 2010 | 08:13 PM
Limey's Avatar
Any benefit
I am getting a O4B edelbrock manifold will there any benefit comapred to lets say a torker or will they be about the same ?? Or is the O4B just like a stocker manifold ??
Old Aug 30, 2010 | 08:21 PM
don71's Avatar
same but different
I'm thinking the 04B is like an early performer, a dual plane design, where as the torker is a single plane.
04B should make you a good street intake. Yea, its like a stocker but lighter becouse its aluminum.
By the way, you cant' use an HEI with the 04B. You'll need a small body distributor.
Old Aug 31, 2010 | 10:03 AM
You think correctly.
The O4B is a good midrange street manifold. The Torker is designed for higher RPM performance.
Old Aug 31, 2010 | 10:07 AM
Texas Jim's Avatar
Texas Jim
made a mistake w/ a Ford engine years back using a Torker with all milder components, it was too much manifold, and had to buy a dual plane edelbrock, ran much better, like a different engine.
Old Aug 31, 2010 | 10:45 AM
If you have an O4B manifold you can use a Pertronix kit to convert your points distributor to variable reluctance. This works great!
Old Aug 31, 2010 | 11:05 AM
..Why I'm Here: '62 Ford pick-up w/ '71 Olds 455ci/TH400/9" Ford
Maybe because it IS a different engine...
Old Aug 31, 2010 | 04:28 PM
cutlassefi's Avatar
Exactly, if it was a small block Ford then the runners were about 2 inches long!
Not the case on a 455 Torker, they're much much longer. Actually makes the manifold O.K for the street as long as it's mated to the right combo.
Old Aug 31, 2010 | 08:20 PM
dc2x4drvr's Avatar
Just swapped a Torker for an 04B, a little better low end, and throttle response, I had to clearance the back of the manifold for my MSD 'Ready to Run' distributor, which has a smaller dia. than an HEI..
Old Aug 31, 2010 | 08:23 PM
Limey's Avatar
thanks still debating on it ............
costpenn
Sep 20, 2014 06:21 AM
dhartley72
Mar 24, 2011 05:38 AM
stuart
Aug 14, 2004 02:24 PM
