points to hei
Old May 23, 2010 | 01:50 PM
1973olds98's Avatar
points to hei
I bought a hei distributer...Does i use the hot wire that was going to the coil on the hei distributer.
Old May 23, 2010 | 01:59 PM
panos's Avatar
Usually the hot wire to the coil has only about 8 volts and u gonna need 12 volts for the hei but u can always mesure the wire that u already have with a voltmeter.
Old May 23, 2010 | 02:39 PM
1973olds98's Avatar
Ok thtas what i was thinkin..Where else could i get the 12 volts from,,any ideas
Old May 23, 2010 | 02:54 PM
1973olds98's Avatar
could the ballast be removed to get the 12 volts,,If so where on the wire harness is it?
Old May 23, 2010 | 06:24 PM
geckonz08's Avatar
try this
http://www.cadvision.com/blanchas/54pontiac/hei.html
Old May 23, 2010 | 06:48 PM
jensenracing77's Avatar
i think there is an ignition power terminal at the fuse box. you can run it from there to the distributor. the factory never uses a resistor that can be removed that i know of. the only ones i seen were a resistor wire. the entire wire made resistance so it could not be used for the HEI.
Old May 23, 2010 | 07:23 PM
Blk71SX's Avatar
in the fuse block, to the right of the stop fuse is a tap labeled IGN. if you feel the need to fuse, you can inline fuse it.
Old May 23, 2010 | 07:42 PM
geckonz08's Avatar
k . Just to sorts complete the info , what size fuse pls ??
mike
Old May 23, 2010 | 08:11 PM
Blk71SX's Avatar
vehicles with factory HEI have a 12ga wire for power, I'd use a 30A
Old May 24, 2010 | 08:34 PM
64Rocket's Avatar
I thought '73 and newer used "HEI" dist. I have never seen a '73 without an "HEI".
Gene
Old May 25, 2010 | 05:44 AM
Blk71SX's Avatar
the High Engery Ignition was available in limited models in 73, RPO K86, was standard across all lines in 75.
joepenoso
Jun 4, 2014 01:56 PM
oldsmobilty
Aug 8, 2013 12:19 PM
1973olds98
Oct 29, 2010 09:35 PM
Wyze
May 14, 2010 01:29 PM
silverriff
Jun 2, 2008 12:26 PM
