Air filter options 455 1970 A-bod
Old May 22, 2024 | 07:53 AM
rfpowerdude's Avatar
I am getting close to being "done" with the 455 install, however, with a stock "S" hood, I don't have much room now for air filter options. It has a Quick Fuel (Holley) Brawler on a 1" spacer on top of a Holley Street Dom intake. It is quite tall. This is the last thing to buy before driving it regularly.
What have others done in this situation that didn't require changing the hood? Low profile carb hat to remote-ish filter? What did you use?
Not sure how to deal with this yet...
Old May 22, 2024 | 08:29 AM
Fixed your title. You might look into this one and you may need to remove the spacer.
1964-1972 Chevrolet Open Element Air Cleaner Kit (ss396.com)
Old May 22, 2024 | 02:51 PM
The base of that is flanged for a QJet horn.
Old May 22, 2024 | 03:01 PM
It fits my 3310 Holley with manual choke. Not sure about an electric choke which is why I suggested looking into it.
Old May 22, 2024 | 04:21 PM
Ah, cool, I just have very little clearance above the carb horn. I am gonna go out and measure it, but it is looking like I can't have anything taller than about 3.5" above the carb circle base. That's like only 2" above the horn before I am into the hood...
Old May 22, 2024 | 07:57 PM
Why do you think you need the 1" spacer?
Old May 22, 2024 | 08:56 PM
I was wondering when I’d be asked that haha. I needed some spacing due to the secondary accel pump hitting the intake carb flange. The intake is flanged for square (Holley) AND spread bore (QJet) and is an issue. I could likely get away with a 1/4”. However, a 1” spacer was easy to get. Now, I wish I had rethought this whole stackup.
I made measurements tonight with crumpled aluminum foil and the maximum I can be is 3.5” from carb air cleaner flange to the top of the air cleaner. That’s when it touches at the shortest point.
3.5” at the front to the top of the foil. There’s nothing I have found that is less than that except for something like this:
https://www.summitracing.com/parts/hly-64280
or this
https://www.summitracing.com/parts/spe-771
Holy crap. Expensive.
Old May 23, 2024 | 05:52 AM
If I really wanted to get that 1" back, I would pull the carb, stuff rags into the intake and grind the area that needs clearancing so the carb can just mount directly to the intake. If I can't find something that will work, I just may have to do that.
Old May 23, 2024 | 06:13 AM
I don't wanna do this, but it may be ok temporarily to keep dirt out of carb.
https://www.summitracing.com/parts/edl-1002
Old May 23, 2024 | 07:32 AM
72455's Avatar
1972 U code Supreme
or this
Just throwing this out there...would it possible to do a little "massaging" of the flange so the pump would clear? Then you'd be able to go with a more practical setup.
Old May 23, 2024 | 08:50 AM
Check out my post #8.
But yes, this would be the "right" way to do it. I will likely do that later and just buy the POS Edelbrock triangle right now to get me on the road without sucking anything into the carb...
Old May 23, 2024 | 09:13 AM
fleming442's Avatar
Allstar makes spun aluminum bases for cheap in Summit. I have a 2 1/2 drop I can send you, if you want.
Old May 23, 2024 | 09:17 AM
I saw those, however, with the electric choke and aftermarket throttle linkage stuff, I wasn't sure if any one of them would clear everything with that much drop.
Call or text me and we can bounce it off each other...
Old May 23, 2024 | 09:51 AM
lunaboy's Avatar
The Rocket Astronomer
toranado air cleaner may work, its a low ptofile unit.
Old May 23, 2024 | 10:22 AM
On a Holley 4150 w/electric choke?🤔
Old May 23, 2024 | 10:32 AM
The Toronado INTAKE is low profile. The air cleaner height is limited by the air filter element. And think about dropped base air cleaners before you use one. At some point the inlet restriction becomes the clearance between the under side of the air cleaner lid and the air horn, which negates any flow benefits from the taller intake. Those K&N filter lids don't help if they are butted up against the underside of the hood.
Old May 23, 2024 | 12:29 PM
What Bruce and I are gonna try to do is use a drop base and then adjust where the top ends up by selecting a filter element that maximizes height but is *just* under the hood line. The hood is a fixed amount above the air horn of the carb. We wanna try to have the lid end up just under that. This will maximize the lid location above the primary air horn.
Old May 23, 2024 | 01:06 PM
Those paper air filters can be crushed to a lower profile. When I worked at auto parts stores I saw quite a few folks come in with a squashed air filter.
Old May 23, 2024 | 01:08 PM
Crush to fit!!🤣🤣
Old May 23, 2024 | 03:40 PM
v8al's Avatar
Registered Olds Owner
Agree - get the lowest drop base air cleaner that will clear the HEI, throttle linkage and fuel feed lines. Then figure out your filter size to get you where the lid/stud needs to be. I'd think you should be able to get at least a 4" filter in there and probably more.
Old May 25, 2024 | 12:51 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Suprised it is so tight with the S hood. It is a nice change from a flat G body hood. I currently have a RPM intake, 3/4" spreadbore to squarebore adapter, Speedmaster throttle body and factory air cleaner converted to dual snorkel on my 358. I ran an Ebay special 14" drop base on my G body. Just fit the tallest filter possible.
Old May 26, 2024 | 05:48 AM
I hate the look, but at least it won't suck in road crap. I need to change out the throttle bracket to something small and simple and then do the drop bass air cleaner. I have about 1/2" of clearance
Old May 26, 2024 | 08:22 AM
I just noticed you’re missing the AC compressor. Any plans for that system?
Old May 26, 2024 | 08:26 AM
Yes, I have all of the original hardware. The compressor is long since been toast. I was going to reinstall everything for completeness, but then I would have to pull it all again just to replace it when I start that project. That is the next big thing to do especially here in Florida. Sorta like you out west except with humidity🤣
Old May 26, 2024 | 08:33 AM
Sorta like you out west except without the humidity🤣
I know Kenneth knows humidity having grown up in Louisiana.
th3ric3m4n
Sep 27, 2017 01:48 PM
76olds
Aug 26, 2016 08:56 AM
Jul 5, 2012 09:34 AM
bjtstarfire
Jan 19, 2008 03:55 AM
