Is the lifter valley baffle needed with a 455
Old Jan 4, 2024 | 09:37 AM
Isaiah406's Avatar
I'm nearly finished rebuilding a 455 for my 77 cutlass. I'm using a stock turkey tray intake gasket and I cannot find the factory baffle that covers the cam. If I leave it out will it cause any problems? I recall an olds 350 that I swapped intakes on not having it.
Old Jan 4, 2024 | 09:44 AM
Is the intake valley baffle needed?
Old Jan 4, 2024 | 09:47 AM
Search can be your friend...
Do I need to use the valley pan?/Oil lifter baffle
Old Jan 4, 2024 | 01:49 PM
The turkey tray IS the baffle that keeps oil off the underside of the intake manifold..
Old Jan 4, 2024 | 03:24 PM
Isaiah406's Avatar
this is the piece I'm talking about. I actually put the intake on today. And then I found this thing that I left out
Old Jan 4, 2024 | 03:39 PM
Yeah, that "thing" is the valley baffle. As stated in the links I provided it "appears" hit & miss if all 350 got them - apparently. I don't know for sure. Also, as indicated in the links I provided apparently all the 455 got them - again, I'm not sure. I'm going to suggest you don't "need" to remove the intake manifold and re-place what you found - you'll most likely be just fine if you used the turkey tray gasket.
Old Jan 4, 2024 | 03:41 PM
Isaiah406's Avatar
Thanks man. I'm just gonna leave it then. That iron manifold was not fun to install
Old Jan 4, 2024 | 03:52 PM
Eh, what's a mere 55lbs. Yeah, they're a beast.
Old Jan 5, 2024 | 05:05 AM
Dynoking's Avatar
This is where rebuilds go wrong. Olds engineers used unique designs and assembly procedures for a reason. That is what made the Olds V8 a long lasting quality product as compered to other production engines of the time.
The purpose of the lifter baffle is to direct oil that is spun off the rotating camshaft back down to the lifters and cam lobes which is a critical but non-pressurized lubrication friction point. The irony here is premature camshaft lobe/lifter failure is often brought up in these forums. The cam and lifter manufacturers, the EPA, and the oil companies are often blamed but here we are leaving out parts that the engineers put in to prevent exactly that. Humm...
Will the engine start and run without it? Yes. Will not using it affect drivability? No. Will it affect long term durability? Roll the dice. Let us know how that works out. IMO that baffle should have been washed in solvent, hot tanked, washed again, scrubbed with soap and hot water until it was surgically clean, then reinstalled as originally designed. I'll save the purpose of the turkey tray for another time.
Carry on...
Old Jan 5, 2024 | 07:30 AM
67OAI's Avatar
Old(s)GuysRule
The low deck (330, 350, 403, etc.) have closed casting area around the camshaft tunnel and thus do not need the baffle as found on the tall deck (400, 425, 455) engines.
Old Jan 5, 2024 | 12:11 PM
Thanks for that info. I was wondering why none of my 350s ever had a baffle, and now I know!
Old Jan 5, 2024 | 01:02 PM
Me too. Good info.
Old Jan 6, 2024 | 07:16 AM
Isaiah406's Avatar
Gonna take the intake off and put it in. Now I know why it's necessary. Thanks for the ìnfo
Old Jan 6, 2024 | 09:10 AM
cutlassefi's Avatar
You’re wasting your time. I’ve assembled and torn apart multiple Olds big blocks with the aftermarket baffle, and they were fine without the original one. But do what you want.
hackmansr
Sep 17, 2014 05:48 PM
GOSFAST
Dec 29, 2013 10:50 AM
442Dave
Aug 29, 2012 06:44 PM
Stevec
May 27, 2011 07:35 PM
Insom
Oct 16, 2010 07:52 AM
