Is the lifter valley baffle needed with a 455
I'm nearly finished rebuilding a 455 for my 77 cutlass. I'm using a stock turkey tray intake gasket and I cannot find the factory baffle that covers the cam. If I leave it out will it cause any problems? I recall an olds 350 that I swapped intakes on not having it.
Yeah, that "thing" is the valley baffle. As stated in the links I provided it "appears" hit & miss if all 350 got them - apparently. I don't know for sure. Also, as indicated in the links I provided apparently all the 455 got them - again, I'm not sure. I'm going to suggest you don't "need" to remove the intake manifold and re-place what you found - you'll most likely be just fine if you used the turkey tray gasket.
This is where rebuilds go wrong. Olds engineers used unique designs and assembly procedures for a reason. That is what made the Olds V8 a long lasting quality product as compered to other production engines of the time.
The purpose of the lifter baffle is to direct oil that is spun off the rotating camshaft back down to the lifters and cam lobes which is a critical but non-pressurized lubrication friction point. The irony here is premature camshaft lobe/lifter failure is often brought up in these forums. The cam and lifter manufacturers, the EPA, and the oil companies are often blamed but here we are leaving out parts that the engineers put in to prevent exactly that. Humm...
Will the engine start and run without it? Yes. Will not using it affect drivability? No. Will it affect long term durability? Roll the dice. Let us know how that works out. IMO that baffle should have been washed in solvent, hot tanked, washed again, scrubbed with soap and hot water until it was surgically clean, then reinstalled as originally designed. I'll save the purpose of the turkey tray for another time.
Carry on...
Carry on...
