new gaskets
Old Oct 10, 2023 | 04:30 PM
Chuxter's Avatar
1970 Cutlass Supreme
new gaskets
So I have my engine out on a stand. Im going to repaint it. I am putting a new water pump on it and I have been advised to go ahead and put a new timing chain set and oil pump in while its out. My question is should I pull t he intake and put new gaskets there too while its out?
Old Oct 10, 2023 | 05:05 PM
Sugar Bear's Avatar
What are you working on? Is the current intake stock? Is it aluminum or cast iron? Does it show any sign of coolant leakage at any of the four corners? Does it leak any oil at the front or rear?
If it is completely dry I'd leave it alone, getting a good reseal can be tricky.
Old Oct 10, 2023 | 05:56 PM
Chuxter's Avatar
Its all stock out of a 74, 98. Hasn't been run in years and there was some evidence of oil leakage at the rear of the engine around the distributor. I did have it started long enough to run the prime in the carb before i pulled it.
Old Oct 11, 2023 | 11:17 AM
Since you have the engine out of the car go ahead and replace all the gaskets. At least the intake, valve covers, timing chain & oil pan. If you don't you might reinstall it and find out the oil pan gasket leaks.
Old Oct 11, 2023 | 02:25 PM
Chuxter's Avatar
Have all of them except intake now. Is there a particular brand that is recommended for the intake gasket?
Old Oct 11, 2023 | 02:58 PM
I use the FelPro intake manifold gasket but I cut the turkey tray out of the center. Also, use the Right Stuff gasket maker instead of the included end rails.
Old Oct 11, 2023 | 04:12 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I would also replace the rear main bearing seal. A lot easier with the engine out of the car/
Old Oct 11, 2023 | 04:23 PM
Chuxter's Avatar
Sooo you don't need the turkey tray part? What is it there for?
Old Oct 12, 2023 | 03:53 AM
The turkey tray is there to keep the oil off of the bottom of the intake manifold. I've NEVER been able to successfully install a fully intact turkey tray intake manifold gasket. I've often wondered how the intake manifold and intake manifold gasket were installed in the factory.
Miles71
Jul 19, 2016 02:11 PM
my72olds
Sep 24, 2015 07:56 PM
.Rocket.Man.
Jun 4, 2015 02:06 PM
Jedidiah
Sep 16, 2013 01:54 PM
dhowe
May 21, 2009 06:07 AM
