400 Olds camshaft identification
Old Aug 13, 2023 | 01:56 PM
h/o guy's Avatar
Hi Everyone,
I need some help identifying the specs on a camshaft I just removed from a customers engine.
This engine was unfortunatley built by Mondello Performance Products about two years ago and has never run correctly for what I am finding are various reasons and poor assembly practices.
Anyways, I am trying to figure out the specs on the hydraulic flat tappet cam I removed from this 65' 400 "B' block from the customer's 65' 442. I am suspecting an incorrect cam that may be a 39* cam instead of the proper 45* cam.
There is a stamped part / grind number in the back which is 413985 but there are two hand engraved numbers above that which are 117809 and 414017. I cant find these numbers anywhere, even in older Engle or Elgin catalogs which are two of the cam brands Mondello most often uses,
Any help here would be appreciated.
Sincerely,
Grant
Old Aug 13, 2023 | 04:24 PM
cutlassefi's Avatar
Hey Grant,
Did you try calling Mondello? Lynn is dead so maybe they’ll tell you what it is.
Just a thought.
Old Aug 14, 2023 | 04:12 AM
BillK's Avatar
Grant,
It might take less time to just put the cam back in the engine and put a degree wheel on it and map it out.
Old Aug 14, 2023 | 07:51 AM
h/o guy's Avatar
Thak you on both responses. Good ideas on both counts. My suspicion is that this cam is a 39* unit and not the 45* cam it should be
w30hurstolds
Feb 6, 2017 08:10 PM
Almond900
Aug 11, 2016 06:58 AM
thibidaux
Jul 6, 2015 04:07 PM
dsolomon
Feb 12, 2011 03:32 PM
442 Guatemala
Jul 24, 2007 11:51 PM
