Cam question
Old Aug 14, 2023 | 03:13 PM
bw1339's Avatar
Cam question
All things being equal in a '68 Toronado 455 engine, how would this cam behave in the different RPM ranges (with 9.6:1 compression) vs the stock Toro camshaft and 10.25 compression?
Advertised Duration (Int/Exh): 262/268; Duration @ .050 (Int/Exh): 219/227; Gross Valve Lift (Int/Exh): .499/.510; LSA/ICL: 112/108; Valve Lash (Int/Exh): Hyd/Hyd; RPM Range: 1300-5500
https://www.lunatipower.com/voodoo-h...8-262-268.html
Thanks.
ben442
Nov 12, 2022 01:28 PM
michael l
May 3, 2022 07:10 PM
HarrySlother
Jul 15, 2021 04:26 PM
marklt
Apr 23, 2015 06:11 PM
WoofWagon
Apr 30, 2012 01:08 PM
