Cam Question
Old Nov 12, 2022 | 04:34 AM
ben442's Avatar
Cam Question
Comp cams shows the xe284 cam requires 9:1 compression.
What are the effects of using the same cam but increasing the compression to 10:1 ?
Old Nov 12, 2022 | 05:24 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Is that the 240/246 duration cam? You want 10 to 1 with that cam, 9 to 1 would would have low cranking compression with that duration and probably be a dog. You will need a higher stall and deeper gearing as well.
Old Nov 12, 2022 | 05:42 AM
ben442's Avatar
That the one, I'm building a 455 aiming for 10.5:1 compression
Old Nov 12, 2022 | 12:07 PM
cutlassefi's Avatar
10.5:1 on what gas?
Old Nov 12, 2022 | 12:34 PM
ben442's Avatar
94 octane is available here
Old Nov 12, 2022 | 01:28 PM
cutlassefi's Avatar
Good for you. You’ll be fine with that cam and anything above 9.5:1. Just make sure you degree it as per the Cam card. I believe it calls for 4° advance.
michael l
May 3, 2022 07:10 PM
rfpowerdude
Feb 26, 2022 02:45 PM
wr1970
Jun 20, 2020 07:51 AM
marklt
Apr 23, 2015 06:11 PM
